Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Big Block A body Tech
A Body 383 need Header info
Thread Tools Search this Thread Display Modes
Old 05-24-2012, 01:34 AM   #1
02sixxer
Senior Member
02sixxer's Avatar
02sixxer's Flag is: United States
Has anyone put in 2" tti headers on a 383 with stock heads and stock stearing. I called TTI to see if it would fit since they fit the 440 with stock heads and the answer I got was maybe. It fits some 383's and other it interferes with the stearing. Just want to see if anyone else hs done it and if so what had to be done or if it fit with out modification. Its hard to believe the 1 3/4" fit without a problem and the 2" hits the steering linkage. That means the the 1 3/4" is 1/8" from the linkage. is that correct.
02sixxer is offline   Reply With Quote
Old 05-24-2012, 06:39 PM   #2
BBBCUDA
Senior Member
BBBCUDA's Flag is: United States
I have them on my 383 with factory iron heads. They clear a mini starter, (barely). They touch the block bellhousing area on the passenger side, but not enough to affect gasket seal. No issues with steering. I do have a motor plate, so no info on mounts. They are super close, just a variance in engine mounts might be a make or break deal. Pretty expensive headers to guess on. A very well qualified engine builder told me my 2"ers are way too big for a 383, and I'm giving up a lot of power. The 383 is temporary, so thats not a big deal. I did a '67 Dart with a 440 and the 2" headers, MUCH better clearance.
BBBCUDA is offline   Reply With Quote
Old 05-24-2012, 06:52 PM   #3
zac_F71
Senior Member
zac_F71's Flag is: United States
I plan to make my own- Summit has BB header flanges with tubing stubs welded on them.. they're 2" IIRC but plan to step them down to 1 3/4"
zac_F71 is offline   Reply With Quote
Old 05-25-2012, 12:09 AM   #4
02sixxer
Senior Member
02sixxer's Avatar
I plan on having the 383 for about a year. I have a 440, but dont have the money to build it the way I want right now. I dont want to buy the 1 3/4" just to need 2" for the future build.
Did you make your own plate or buy a particular brand? That may be the way to go.
Old 05-25-2012, 01:28 AM   #5
72BBSwinger
Senior Member
72BBSwinger's Avatar
72BBSwinger's Flag is: United States
The pitman arm stud will catch on the 2" ers. Ballpeen or raise the engine about a 1/4".
72BBSwinger is offline   Reply With Quote
Old 05-25-2012, 06:36 AM   #6
BBBCUDA
Senior Member
Mine was a Ray Barton plate, and I cut it using a friends for a pattern, so who knows if it is in the stock position. This might be why I had no steering issues. I used this plate as a pattern for the plate in the 440 Dart I did, and that one cleared everything beautifully, T-bars, steering, etc. I need to make a pattern off the plate the next time it comes out. One other thing to note, the 2" are very snug around the shifter arm on a 727. It's an excercise in patience getting a cable on and adjusted. Make secure tabs to provide plenty of air space off the headers. Changing out the cable after 3 passes because it it melted sucks. Sucks even more the second time.
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
header options for a 383/833 setup? swinger74 Mopar General Discussions 0 05-14-2012 06:47 PM
Need info. on how rare is a 383, 67 barracuda undertaker Mopar General Discussions 3 01-30-2011 06:44 PM
Need Info On 383 Heads superdart426 General Discussion 3 10-01-2009 11:26 PM
383/496 stroker (440source) ANY INFO PLS 68Ozfish Small Block Tech 2 03-19-2007 11:23 AM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.18291 seconds with 19 queries
