Hey, I previously had this thread going in the Racers forum but decided to needed to be moved here as I plan to drive the car on the street WAY more than it will see any race track.
I have ordered and received my kit from Race-Mart. The kit is the cast crank with the ICON forged pistons, bearing, rings, rods etc.
http://www.race-mart.com/Scat_Manufa...T-1-98013.html
Everything is at the machine shop now and they are waiting on me to bring them a cam to get started on the engine. I have contacted Comp Cams and they have suggested the XE284H camshaft. I have also contacted Hughes and Lunati through the form on their website, but have not got a reply form either.
What would be the cam that you suggest? The car will be mainly street driven with an occasional trip down the 1/4 mile.
Motor/Vehicle specs:
'74 Duster
3100 lbs, 3.23 rear gear, 3000 stall, 904 with reverse valve body
Engine
340 bored .040 with the SCAT stroker kit
Edelbrock aluminum heads/out of the box
10.37:1 Compression ratio
Heddman headers/3 inch exhaust with x pipe/dumps before rear axle
Any suggestions, insight would be appreciated.
