Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Electrical and Ignition
help please wiring questions 73 Duster
Thread Tools Search this Thread Display Modes
Old 05-25-2012, 03:35 PM   #1
rp23g7
Senior Member
rp23g7's Avatar
rp23g7's Flag is: United States
So, i bought a engine harness from Evens, for the 73 Duster.
The questions i have is hooking the ballast resistor wires up.
My Duster has a 4 prong BR.
The Evens has a 2 prong setup. I called them, no answer.
The Dusters old harness has ....
Upper right green/w red stripe to ignition box
lower right brown wire, going to some connector that is not attached to anything
upper left 2 blues, 1 i think goes to the alt, and the other goes down to the lower left.
lower left has the blue from the upper left, and a green and yellow to the ignition box
the new harness has a single blue with white stripe, and a double wire single connector, Brown wire and blue wire.
Anyone have a idea how to hook this up
rp23g7 is offline   Reply With Quote
Old 05-25-2012, 06:49 PM   #2
67Dart273
67Dart273's Avatar
67Dart273's Flag is: United States
If your ignition ECU is a so called "4 pin" the new harness will work
You cannot necessarily tell a 4 pin from a 5, as some 4 pin ECUs have 5 pins
You'll have to use an ohmeter and see if the 5th is connected to anything
The difference is one wire and half the resistor. Here are the two diagrams, 4 and 5 pin ECU
You can wire it up for a 4 pin ballast, and it will work with EITHER 4 or 5 pin ECU, but the 5 pin ECU MUST have a 4 pin resistor
from here:
http://www.mymopar.com/index.php?pid=31
The older 5 pin ECU/ 4 pin resistor. Essentially, Mopar eliminated the left half of the dual resistor, and the wire coming off the bottom left of the resistor
If you decide you need the 4 pin resistor PAY ATTENTION to the notch depicted in the drawing at the bottom of the resistor. This properly orients the resistor, as the left and right sides are different resistance.
The newer 4 pin box/ 2 pin resistor for comparison
[img[http://www.mymopar.com/downloads/Ignition_System_4pin.jpg[/img]
67Dart273 is online now   Reply With Quote
Old 05-25-2012, 09:28 PM   #3
rp23g7
Senior Member
rp23g7's Avatar
I friggen gave up, and put the old one back on, cant figure out whats up. Now my headlights dont work.
Strange issue, my tail lights and markers work. My headlights, grill lights and front markers dont.
I have power at each side of all fuses, i have power at the high beam switch, i have power at the headlight relay.
I took a headlight out, and tested the connector, weird issue, with the head light switch off, i have power at all three connectors on the plug, with the switch on, there is no power at any connector on the plug. GRRRR
Old 05-25-2012, 11:13 PM   #4
rp23g7
Senior Member
rp23g7's Avatar
ok so feel free to call me a dork, i was installing the wrong harness, i ordered 3, one for each car, i was trying to put the 70 Duster harness on the 73, oopps. It started right up.
Headlights still dont work though.
Old 05-25-2012, 11:31 PM   #5
67Dart273
67Dart273's Avatar
A good starting place is to check the dimmer switch. With the headlights on, two terminals should be hot to ground, and switching the dimmer should change to the cold terminal.
If you have power there (and the panel "high beam" indicator works) then it's probably either in the bulkhead connector or out at the headlights, CHECK THE GROUND pigtail
Old 05-26-2012, 12:00 AM   #6
rp23g7
Senior Member
rp23g7's Avatar
just checked that, with the headlights on, i have power at all three terminals, both low and high.
With lights off i have no power on any of the three.
Bad dimmer switch?
Old 05-26-2012, 12:06 AM   #7
moparisbest
Senior Member
moparisbest's Avatar
moparisbest's Flag is: United States
Send a message via Yahoo to moparisbest
Check the ground up front by the rad make sure there is a ground from battery to rad suport
moparisbest is offline   Reply With Quote
Old 05-26-2012, 12:40 AM   #8
rp23g7
Senior Member
rp23g7's Avatar
Tried switching the 70 and 73 dimmer switch, that didnt work, looked at the ground, it was trashed, yrs of being by the battery had done it in, and i probably broke it doing the harness. Stripped and grounded it to the battery and the head lights worked.
Fixing tomorrow, thanks eveyone.
Old 05-26-2012, 01:00 AM   #9
67Dart273
67Dart273's Avatar
See? You can do it!!
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Alt wiring questions kempkan Electrical and Ignition 7 02-21-2012 08:02 PM
wiring questions motorhead446 Electrical and Ignition 2 08-02-2011 12:12 PM
Wiring Questions 74 DART' Electrical and Ignition 3 09-27-2008 04:41 PM
Dash wiring questions: sharpie Electrical and Ignition 6 04-17-2008 09:07 PM
a few electrical/wiring questions 68 A Electrical and Ignition 7 04-26-2007 06:09 PM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.29191 seconds with 22 queries
