Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Small Block Tech
360 Horse Power
Small Block Tech
Thread Tools Search this Thread Display Modes
Old 05-27-2012, 07:53 PM   #1
kyles73dart
Member
kyles73dart's Avatar
kyles73dart's Flag is: United States
360 Horse Power
I have a 360 that i am building. It has a summit camshaft that has an rpm range is from 2000-4500, duration @.050" int./exh.= 218 deg/228 deg, Lift is .441/.441.
The pistons are standard bore. We also replaced the piston rings and all the bearings. Has Stock 360 heads with Long tube summit headers.
So I would like to know estimated HP it would produce. Thanks
kyles73dart is offline   Reply With Quote
Old 05-27-2012, 08:01 PM   #2
crackedback
Senior Member
crackedback's Avatar
330 maybe. More like 300-310
crackedback is offline   Reply With Quote
Old 05-27-2012, 09:00 PM   #3
OldmanRick
Layin Low Member
OldmanRick's Avatar
OldmanRick's Flag is: United States
Without zero decking the piston height, and/or milling the heads i agree with crackedback's more like number around 300 hp. that's a pretty low compression engine in stock form, but the plus side is you should be able to run it on any pump grade gas you choose.
OldmanRick is online now   Reply With Quote
Old 05-27-2012, 10:57 PM   #4
RustyRatRod
Senior Member
RustyRatRod's Avatar
RustyRatRod's Flag is: United States
Send a message via Yahoo to RustyRatRod
I was thinkin more like 250-275. Remember compression is probably under 8:1. It has headers, but it has a larger cam than stock bleedin off more cylinder pressure. Aint got much of that to begin with.
RustyRatRod is online now   Reply With Quote
Old 05-27-2012, 11:18 PM   #5
OldmanRick
Layin Low Member
OldmanRick's Avatar
Quote:
Hopefully with some good machine work, and a intake and carb that's perfect for that combo, and some favorable factory clearances it would get to my number, but just a freshened block and heads and bolted together i'll agree with the 250-275number. Not that there's any thing wrong with that. Could be a nice driver.
Old 05-28-2012, 12:10 AM   #6
RustyRatRod
Senior Member
Quote:
Oh hell yeah. That's more kick than most people realize.
Old 05-28-2012, 07:45 AM   #7
moper
Just do like everyone else does... It's 400hp
I agree with the above tho, 275-300hp unless some tricks were used, and that's plenty for an A body cruiser or cruiser/racer.
moper is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Horse Power Guillermo Forced Induction Mopar 1 10-25-2011 12:01 PM
horse power iggys68dart Small Block Tech 12 12-15-2010 08:34 AM
What horse power do you think stansblue72 Small Block Tech 11 04-01-2008 11:23 AM
Horse Power Loss ? Small Block Small Block Tech 12 02-26-2008 08:50 AM
Horse Power TV Keith Mopar Jokes, Funny Stuff, Anything Goes 20 05-29-2005 05:30 PM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.15710 seconds with 20 queries
