Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  CAR AUDIO TALK  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Slant 6 Discussions
Rubber gasket vs. a cork gasket
Slant 6 Discussions
Thread Tools Search this Thread Display Modes
Old 07-05-2012, 06:50 PM   #1
christopher.brandon
Member
christopher.brandon's Avatar
christopher.brandon's Flag is: United States
Send a message via Yahoo to christopher.brandon
Hello all,
I was wondering which gasket for a valve cover is better: rubber or cork? Or is it just more of a preference? Common sense tells me that a rubber gasket would be better, but wanted to get some expertise before I change it out.
I noticed that ther was oil under my car, and that it was dripping down the side of the block. I made my first attempt at ever installing a valve cover gasket. To say the least, I didn't do a very good job, and she is leaking again. I made a rookie error of thinking that tightening the bolts even more would make a better seal. There is that common sense again. Anyhow, I want to right my wrong and do it again, but I want to make sure I get the best gasket for the job. The original gasket was cork, and rather new, as well as the last one I put in. I suppose that is why I am leaning towards a rubber gasket.
The engine this is for is a 225 slant 6.
christopher.brandon is offline   Reply With Quote
Old 07-05-2012, 07:02 PM   #2
TrailBeast
Slightly Twisted Member
TrailBeast's Avatar
TrailBeast's Flag is: United States
I HATE cork gaskets.
Clean the cover real good of all oil and junk.
1/8 in bead of red silicone on the cover (And all the way around the bolt holes)
Rubber gasket then another 1/8 bead on the engine side of the gsket and slap er on wet.
When putting the silicone on, smooth it down a little with your finger to spread it a little.
Tighten in a rotating pattern like you would a cyl head just till snug (Not tight) a little at a time until they are all about the same.
If you do it this way, after a day you could take the bolts out and throw em away and it will still not leak.
Did it once to prove it to someone. (Drove it 15 miles to his house and back)
TrailBeast is offline   Reply With Quote
Old 07-05-2012, 07:26 PM   #3
christopher.brandon
Member
Awesome, thanks!
Old 07-05-2012, 07:31 PM   #4
RustyRatRod
Senior Member
RustyRatRod's Avatar
RustyRatRod's Flag is: United States
Send a message via Yahoo to RustyRatRod
Cork always ends up absorbing oil and eventually leakin. GHEY.
RustyRatRod is offline   Reply With Quote
Old 07-05-2012, 07:38 PM   #5
rob_robinson87
Senior Member
rob_robinson87's Avatar
rob_robinson87's Flag is: United States
Your type of valve covers will make a difference too. I know the stock covers on my 318 and 340 with the thinner rubber gaskets hit on the intake and will not seal. The thicker cork gaskets bring the valve cover gaskets up high enough so they somewhat seal.
rob_robinson87 is offline   Reply With Quote
Old 07-05-2012, 07:40 PM   #6
805moparkid
SS And AFX Worker Bee
805moparkid's Avatar
805moparkid's Flag is: United States
i hate the rubber gaskets... never can get them to seal even with silicon on both sides... with the cork i just silicon it to the cover and its reusable a half a dozen times...
805moparkid is offline   Reply With Quote
Old 07-05-2012, 07:49 PM   #7
68383GTS
Fish in a basket 67FS
68383GTS's Avatar
68383GTS's Flag is: United States
I always use cork.As 805 said I permatex the gasket to the valve cover and reuse it many times over.Cork will only leak if you over torque your valve cover.If you silicone both sides, have fun getting it apart later.
Jim
68383GTS is offline   Reply With Quote
Old 07-05-2012, 08:00 PM   #8
cudascott
wish I had a Hemi
cudascott's Flag is: United States
If find that the cork works better than rubber simply because it doesn't
Squish so easy, rubber seems more suitable for grooved applications
cudascott is offline   Reply With Quote
Old 07-05-2012, 08:03 PM   #9
TrailBeast
TrailBeast's Avatar
Yep
Old 07-05-2012, 08:19 PM   #10
slant6racer
Member
slant6racer's Avatar
I use realgaskets.com
Spray adhesive on valvecover side.
Will
slant6racer is offline   Reply With Quote
Old 07-05-2012, 08:48 PM   #11
TrailBeast
TrailBeast's Avatar
Hey
Thats pretty cool.
Never seen em before.
Are they kinda firm, like dried red RTV?
Will
Old 07-05-2012, 09:24 PM   #12
christopher.brandon
Member
Thank you for all of the input!
I do not have a torque wrench, so what is the general "rule of thumb" for proper tightening? I have heard that you want to get it finger tight, then give it a couple more rotations with a socket wrench. Is that about right, or not?
Old 07-05-2012, 09:29 PM   #13
805moparkid
finger tight and then take it snug...
Old 07-05-2012, 09:50 PM   #14
hypermite
Senior Member
hypermite's Avatar
hypermite's Flag is: United States
I use cork gaskets & always put them on DRY. Whatever type you use theres a couple of things, If it's a stamped steel valve cover, make sure it is absolutley clean & straight where the gasket rests, typically over the years these covers get over torqued & the rails are bent all to hell. If you get the rails straight, clean & you don't over-tighten the bolts, they should seal up for years & years with no trouble.
hypermite is offline   Reply With Quote
Old 07-06-2012, 03:51 AM   #15
cjh
Senior Member
cjh's Avatar
cjh's Flag is: Australia
When fitting a rubber or cork rocker cover gasket ( pressed steel cover), make sure it's clean and dry ( as is the cyl head too), apply Contact Cement to cover and gasket ( the side that goes to the cover),
and stick it to the cover, wait 20 mins, then fit the cover to the head, dry.
The reason for using Contact Cement is to stop the gasket from sliding/squeezing out under pressure, same as having the cyl head clean and dry too.
Contact Cement isn't affected by oil.
cjh is offline   Reply With Quote
Old 07-06-2012, 08:05 AM   #16
stumper
Senior Member
stumper's Avatar
stumper's Flag is: United States
Partly depends on the type of valve cover you have. If you use covers with a flat bottom surface without the outer lip to contain the gasket using a rubber gasket is like trying to pick up jello... I find the rubber impregnated cork gaskets work the best for me - and they are cheap. I use a very thin layer of sealer on the valve cover side just to hold the gasket (let it set up good with the gasket on before putting on the heads), and hand tight plus ~ a quarter turn to start. Let it set over night and put ~ another 1/8 a turn on before running the motor. This method finally has my current RB with Indy heads dry for the first time since I bought it 3+ years ago - and I think I have tried every gasket/combo on the market..
stumper is offline   Reply With Quote
Old 07-06-2012, 08:12 AM   #17
66340SEDAN
I Bleed MoPar
66340SEDAN's Avatar
66340SEDAN's Flag is: United States
Quote:
X2...cork!!
66340SEDAN is online now   Reply With Quote
Old 07-06-2012, 10:43 PM   #18
christopher.brandon
Member
Thank you all for your input. Looks like cork it is!
Old 07-07-2012, 04:47 AM   #19
Valleyant
Valleyant
Valleyant's Avatar
When ever its time for a new valve cover gasket on my slant 6 Valiant daily driver. I take great care to ensure a clean/oil free head surface and a clean/oil free valve cover surface. I also make sure non of the valve cover holes are dimpled in from over tightening. I use a dolly or the edge of a steel work table to hammer those surfaces straight. I then will use very thin bead black rtv on the valve cover to effectively glue the Cork gasket to it. I let it sit over night if possible. Then just before I install the VC....I spray a thin layer of engine enamel onto the gasket. Helps to glue the gasket onto the cylinder head and fill any small voids. I hand tighten all the bolts starting with the centers and working out to the edges. Then use a wrench/socket for final tightening but I concentrate on even tightening on all the bolts. They do not need to be very tight. You do not want to deform or cause the gasket to get squished out from between the VC and head. I like the cork gaskets. my 2 cents...hope it helps.
Valleyant is offline   Reply With Quote
Old 07-07-2012, 05:39 AM   #20
Johnny Dart
Senior Member
Johnny Dart's Avatar
Johnny Dart's Flag is: United States
Cork or rubber gaskets work.I use Edelbrock Gasgacinch to glue the gasket to the valve cover. Put the adhesive on the cover and gasket,and let it setup for a few minutes. Install the gasket on the valve cover. Flip the VC over and put it on a flat surface with some weight on top. Let it dry,pop it on.
Unless you never plan on taking the VC off again (and even then i wouldnt) never put any kind of sealer on the engine side.
Johnny Dart is offline   Reply With Quote
Old 07-07-2012, 01:06 PM   #21
NukeBass
Senior Member
NukeBass's Flag is: United States
I don't remember what I used last time when I put the valve cover on, but when I was trying to get a carburetor to work, the rubber gaskets that come with the rebuild kits and in all of the remanufactured ones I bought wouldn't seal up the gas bowl (Holley 1920). I had to buy cork gaskets from NAPA to get them to stop leaking.
NukeBass is offline   Reply With Quote
Old 07-07-2012, 02:06 PM   #22
Rug_Trucker
Senior Member
Never heard of using contact cement! Might try that sometime. Contact cement is designed to tack up before assembly. So apply and seperate for best results.
I always use 3M "Gorilla Snot" weather strip adhesive. I never glue to the head.
Real pain to try and stick gaskets to the chrome Chinese VC!
Wheel bearing grease on the side that goes to the head. Old VW trick as with them you had to set the valves at every oil change.
Rug_Trucker is offline   Reply With Quote
Old 07-07-2012, 03:41 PM   #23
valentino automotive
VALIENTE VALIANT
valentino automotive's Avatar
valentino automotive's Flag is: United States
If you have stock valvetrain I would use the right stuff. It works super good. you don't need gaskits with this stuff. You make a gaskit with this stuff.
valentino automotive is offline   Reply With Quote
Old 07-07-2012, 03:49 PM   #24
VALIENTE VALIANT
Oh and tighten it with your wrist with a 3/8 ratchet and not with arm leverage.
Old 07-07-2012, 06:45 PM   #25
slantsixdan
slantsixdan's Avatar
slantsixdan's Flag is: Canada
For a slant-6 I prefer the rubber gasket such as Fel-Pro VS-12680R. Do not use any adhesive, "sealer" or other gunkum on it or you will curse yourself the first time you have to remove the valve cover. Do make sure the cover isn't warped round the bolt holes.
slantsixdan is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
rubber oil pan gasket? karl2fast Small Block Tech 2 02-15-2012 09:51 PM
273 cork gasket wanted 65dartcharger Cars and Car Parts Wanted 4 04-11-2011 08:40 AM
Steele Rubber windshield gasket flyboy1400 Body / Interior / Trim 2 03-17-2010 08:58 PM
windshield and rear window rubber gasket 71dartswinger Members Restorations 2 08-20-2009 04:20 PM
wiper motor rubber gasket SGBARRACUDA Cars and Car Parts Wanted 0 10-21-2007 12:54 PM
Fabo Sponsors
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.28295 seconds with 38 queries
