Comp Cam Big Block solid roller
helicoil
Member
St. Louis
I have for sale a NIB solid roller cam ground by Comp Cams and sold under the Sealed Power name.
Part number is TP216 (Sealed Power), CS1123R Speed Pro. Comp Cams grind number is CRB-3 306B-R8
Specs:
Part number: 23-758-9
duration @ .050" 275/275
lobe lift .4167"/.4167"
lobe separation 108
gross lift .625"/.625"
valve timing at .020"
Int OPEN 43 BTDC CLOSE 83 ABDC
Exh OPEN 79 BBDC CLOSE 47 ATDC
valve spring recommended Comp Cams 938
Specs are listed at the bottom of this thread. I have had this for 10 years or so. It is in perfect shape. My Mopar buddy I got it from told me it was runner of a camshaft in a 440.
http://www.forabodiesonly.com/mopar/showthread.php?t=194421
I had to do some homework to get the specs, but they were available and I have a cam card to go with it now.
Price is 150.00 plus shipping and Paypal fees (if used).
I am NEW to the A Body forums but have done alot of trading on other sites, just not a Mopar guy......
Thanks,
