Power to Manual... will this work?
9teen7tSwinger
Sioux Falls, SD
I've read through all the threads regarding power to manual... and I think I am on the right track. I have a 73 duster with disc/drum. The booster is giving me headaches and I really didn't mind the manual brakes on my 70 swinger. I plan on removing the booster, using the adapter plate with my current MC, and this push rod...
http://www.performanceonline.com/Manual-Brake-Master-Cylinder-Push-Rod-kit-with-Boot-18778/
Will this work? My father, which is my go to guy, has never had to convert brakes and was not sure...so I go to my other mopar go to guys.
Can you think of anything else I may need to complete this conversion?
I did this conversion on my Dart Sport with disc/drum. No problem, just get a new manual master cylinder (they sell them at all the parts stores) and you will need a pushrod from a manual setup as well. Should be able to find one on here or eBay. Everything lines up perfectly, a very easy job.
Brakes work great.
On my A body the master is bolted directly to the firewall, not so on B,E,F.
