Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Small Block Tech
opinions on stroker kit?
Small Block Tech
View Poll Results: Which stroker kit?
416 Cast crank 46 56.79%
372 Forged crank 35 43.21%
Voters: 81. You may not vote on this poll
Thread Tools Search this Thread Display Modes
Old 07-26-2012, 07:00 PM   #1
71swing
Senior Member
71swing's Avatar
I got word back from my machine shop that my 340 was seized up from a spun rod bearing and bent rod on cylinder 5. I will be talking it over with them Monday. But Im now shopping for a stroker kit.
The best pricing I have found is from RPM Machine http://www.rpmmachine.com/chrysler-stroker-menu.shtml
Im intrested in the 416 cast crank for the price ( comes with KB hyper dished pistons) but I believe I can maybe get it with forged ones. Or should I step down to the 372 and get forged crack for a little more money?
cast crank more cubes or forged crank less cubes all for close the same money?
71swing is offline   Reply With Quote
Old 07-26-2012, 07:28 PM   #2
dustinmoran91
dustinmoran91's Avatar
dustinmoran91's Flag is: United States
What will it be used for? Street/strip or cruising? Any power adders in the future like NOS/turbo?
dustinmoran91 is offline   Reply With Quote
Old 07-26-2012, 09:19 PM   #3
273
Senior Member
273's Avatar
273's Flag is: Canada
416 good for 500hp and the 372 good for 750hp, so if it a N/A 500hp or less and want to run reasonable rear gears I'd go with 416 kit.
273 is online now   Reply With Quote
Old 07-26-2012, 09:52 PM   #4
Demon416
A-Body
Demon416's Avatar
Demon416's Flag is: United States
Unless you're building a "ground pounder," the 416 cast crank is the way to go. Good for 500 hp all day long.
Demon416 is offline   Reply With Quote
Old 07-26-2012, 10:13 PM   #5
Cudafever
Senior Member
Cudafever's Flag is: United States
I looked at RPM Machine as well as others, when i was pricing a stroker. had a few e-mails with them as well.
Talk to your Machine Shop! they can get you as good, or better "Q" for less. at least my guy did.
Sooo what are you going to do with this eng Mild, wild or CrAzY!!!
And No my eng is not together yet.........But the block is painted
Cudafever is offline   Reply With Quote
Old 07-26-2012, 10:17 PM   #6
71swing
Senior Member
71swing's Avatar
I do have a Zex kit on the car with the old 340. Used it only at the track a few time. Never even finished the first bottle. If I could get high 400's on just the stroker I would sell off the nitrous. I'm just looking for a respectable car for the street. Car already looks good just need to make sure I don't have any problems with any teenagers in their retarded rice burners.
Car has a 727 with a CTR reverse valve body, dynamic 3200 stall converter and 8-3/4 rear with 4:30 gears which I may raise slightly to better highway speed.
Old 07-26-2012, 10:20 PM   #7
OldmanRick
Layin Low Member
OldmanRick's Avatar
OldmanRick's Flag is: United States
Cast crank stroker is plenty enough to get you in trouble on the street....450hp/450tq is good.
OldmanRick is online now   Reply With Quote
Old 07-26-2012, 10:21 PM   #8
Cudafever
Senior Member
3200stall..hmmm
What rpm are you wanting to turn this new motor?
Old 07-26-2012, 10:24 PM   #9
273
Senior Member
273's Avatar
I don't know if true but I've read by time you balance a cast crank with mallory metal it puts you close to forged crank cost.
Old 07-26-2012, 10:40 PM   #10
71swing
Senior Member
71swing's Avatar
Quote:
Originally Posted by Cudafever View Post
3200stall..hmmm
Whatever it needs. Current cam is a mopar purple which I don't think they sell anymore P5007695. 241/241@ .50. .484lift 114* 2600 to 6000rpm range.
If I need to change the cam or converter than I will maybe next spring.
Old 07-26-2012, 10:51 PM   #11
64physhy
Senior Member
64physhy's Avatar
64physhy's Flag is: United States
Quote:
My Forged crank needed balanced with mallory. I think it was around $200 for the balancing.
I would go with the forged 372. That way you have it in case you ever decide to start putting more power to it. The shorter stroke will rev faster, too (not that a 416 would be "slow" revving).
64physhy is offline   Reply With Quote
Old 07-26-2012, 11:28 PM   #12
oldkimmer
oldkimmer's Flag is: Canada
............I think Mike over at MRL..........has a stroker 4 sale.............kim........
oldkimmer is offline   Reply With Quote
Old 07-26-2012, 11:41 PM   #13
srduster340
Senior Member
srduster340's Avatar
srduster340's Flag is: United States
I'd go with the extra cubes and most importantly, torque of the 416. Overall I think it's a better street combo. Lower gears, lower stall if automatic, less rpm and engine wear on the highway and the strip!
srduster340 is offline   Reply With Quote
Old 07-27-2012, 12:27 AM   #14
crackedback
Senior Member
crackedback's Avatar
Build the bigger inch engine. Won't have to turn it more than about 5500 to run in the high tens at 3000-3200# in a good working chassis.
450+ hp is pretty easy to get. Heads make a big difference in how much power gets produced.
crackedback is offline   Reply With Quote
Old 07-27-2012, 12:32 AM   #15
412 Stroker
412 Stroker's Avatar
412 Stroker's Flag is: United States
Dont know where you read that but my cast 4" stroker crank required NO mallory in fact they had to take some weight off.
412 Stroker is offline   Reply With Quote
Old 07-27-2012, 07:17 AM   #16
DJVCUDA
Senior Member
it all depends on the weights of the rest of the rotating assembly.
Price is not always the best bet for parts - in general -
I spent a little more for rods, bu they didnt need any work at the shop - same with the crank - sometimes if you cheap out and the rods or crank need to be worked on at the shop it cancels out your cost savings.
DJVCUDA is offline   Reply With Quote
Old 07-27-2012, 07:32 AM   #17
jimjimjimmy
lobsterman
jimjimjimmy's Avatar
jimjimjimmy's Flag is: Canada
Quote:
kim is right on mike has one killer sb for sale carb to pan dyno tuned for less than you could do it yourself and its a professional built engine.
jimjimjimmy is offline   Reply With Quote
Old 07-27-2012, 10:16 AM   #18
Cudafever
Senior Member
I when with the forged 4.00" stroker because i can make the same power as a shorter stroked eng at a lower rpm. aka a more streetable combo.(better gearing less stall exc.)
And it didn't have to have Mallory metal added. My machinist said it was a Farly light assembly
If you live close to MRL, that might be a good deal!!!!
Old 07-27-2012, 10:21 AM   #19
jerry6
jerry6's Avatar
jerry6's Flag is: Canada
Some of those retarded rice burners are damn fast , nissan gtr from the factory for example .
With 4:30 gears and 3200 stall I'd go for the 372 , but I like doing things the hard way , like building a second 340 as a beater engine instead of going for a 360 . I also like using a forged crank and pistons , but the crowd here seems to think cast crank and pistons are good enough , maybe these days they are .
Good luck with whatever you choose , hope you beat those retarded rice burners !
jerry6 is online now   Reply With Quote
Old 07-27-2012, 11:05 AM   #20
Todlich
Senior Member
Todlich's Avatar
How many tweeners' are going to be driving a $96k+ import?If they are, Iam willing to bet the local law enforcement would like to search their person and vehicle.Hondas,Subarus,Supras,Fairlady/350 and the like Iam sure is what was ment by the OP.
Todlich is online now   Reply With Quote
Old 07-27-2012, 11:23 AM   #21
Baxter61
Senior Member
Baxter61's Avatar
Thats knowledge and experience right there. I learned my lesson once, tried to save $90 or so on a set of pistons. Then to get compression ended up cutting block, heads, which meant intake milled and custom pushrods. I think saving $90 on pistons cost me $380 or so.
Baxter61 is online now   Reply With Quote
Old 07-27-2012, 03:24 PM   #22
71swing
Senior Member
71swing's Avatar
Quote:
http://www.mrlperformance.com/
My build better not even be a 4th of the cost of his motor. At least it better not be.
Old 07-27-2012, 03:51 PM   #23
Bad Sport
HALF A BUBBLE OFF
Bad Sport's Avatar
Bad Sport's Flag is: United States
I don't think you're going to build a stroker motor for 1700.00 bucks, ain't gonna happen.
I've been looking at parts for my 360/408 build and so far I'm coming in at 65 hundred or so, and still don't have everything figured in.
Bad Sport is offline   Reply With Quote
Old 07-27-2012, 04:06 PM   #24
jimjimjimmy
lobsterman
good luck keep us updated on your build
Old 07-27-2012, 06:49 PM   #25
breakstuff
Senior Member
breakstuff's Flag is: United States
$6950 is pretty cheap for what that motor is.
breakstuff is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need opinions on a 408 stroker build bness360 Small Block Tech 30 06-26-2012 12:04 PM
408 Magnum Stroker build opinions dusted72 Small Block Tech 7 08-27-2011 10:09 AM
Idea for a cheap 318 stroker. (opinions?) omahamoparguy Small Block Tech 17 12-22-2010 09:18 PM
your opinions on stroker crank or grinding a factory dudeman601 Big Block A body Tech 13 05-17-2010 11:42 AM
426 stroker kit opinions? BoredandStroked Mopar Performance Issues 15 03-03-2007 11:40 AM
Fabo Sponsors
Powered by: vBulletin Version 3.8.8 Beta 1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.25302 seconds with 39 queries
