Mopar mopar forum
 HOME  FORUMS   MEMBER PHOTO GALLERY  CHAT    REGISTER  FABO STORE
 MEMBER CLASSIFIEDS  VIN DECODER  VIDEO GALLERY
Our Network:  B BODY MOPAR FORUM  C BODY MOPAR FORUM  E BODY MOPAR FORUM  FMJ BODY MOPAR FORUM  PICKUP TRUCK FORUM  FOR JEEPS ONLY
Go Back   For A Bodies Only Mopar Forum > General Off Topic Forums > General Discussion
Need help asap (harmonic balancer)!!!!
General Discussion
Thread Tools Search this Thread Display Modes
Old 07-28-2012, 09:14 PM   #1
muddog
muddog's Avatar
muddog's Flag is: United States
Angry Need help asap (harmonic balancer)!!!!
ok fabo brothers and sisters, i got an 1978 360 engine that was completely gone thru, heres my ?, it was internally balanced and set up for an automatic transmission, now im swapping it in to my 72 dart with an A833 4 speed, what balancer do i need to use, the automatic 1 is 8.9 lbs and ounces, and the manual 1 calls for the 12.2 lbs and ounce balancer, does anybody no which 1 i should use as4 like i originally said it was balanced for the automatic!!!!
muddog is offline   Reply With Quote
Old 07-28-2012, 09:20 PM   #2
crackedback
Senior Member
crackedback's Avatar
It was internally balanced... so you would use an internally balanced damper and flywheel. It takes a bit of work and mallory metal to internally balance a 360. Have a pic of the balancer you used on it when it ran?
If it has a scallop in it, the rotating assembly likely wasn't internally balanced.
The balancer on the front of the engine isn't going to change because you changed transmission.
crackedback is offline   Reply With Quote
Old 07-28-2012, 09:21 PM   #3
66plyValiant
Senior Member
66plyValiant's Avatar
66plyValiant's Flag is: Canada
360's were always externally balanced unless your machinest changed that.....
66plyValiant is offline   Reply With Quote
Old 07-28-2012, 09:26 PM   #4
muddog
muddog's Avatar
yes your right 66plyValiant just found that out from another fabo buddy, now that i no that what balancer should i use ?, like ken just told me it is externally balanced just like what you said, but he did remind me that there is an specific flywheel for a 360 so my ? is 12.2 manual or 8.9 automatic?, i have 2 option here need best advice!!!!!!
Old 07-28-2012, 09:43 PM   #5
crackedback
Senior Member
Where are you getting the info on balancers? To the best of my knowledge, there is an early/non magnum and a magnum balancer... transmission has nothing to do with the balancer.
Old 07-28-2012, 11:03 PM   #6
muddog
muddog's Avatar
in the different parts book, it calls for different balancer depending on application, manual or automatic!!!!! i'll give summit a call tomorrow and ask there tech!!!!!!! looking at ur picture crackedback mine doesnt have that notch in it!!!!
Old 07-28-2012, 11:10 PM   #7
oldkimmer
oldkimmer's Flag is: Canada
.............post a pic of urs..........kim........
oldkimmer is online now   Reply With Quote
Old 07-29-2012, 12:25 AM   #8
fishy68
Tyr Fryr's Inc.
fishy68's Avatar
fishy68's Flag is: United States
I've never saw a diferent balancer used for auto vs. manual. The flywheel is different of course. Like Rob said there's the pre magnum (actually 2 versions of it but the offset of the weight was the same, just a different design) and non magnum balancers and that's it.
fishy68 is online now   Reply With Quote
Old 07-29-2012, 01:56 AM   #9
muddog
muddog's Avatar
yah i here yuh, theres 2 different parts number, 1 for automatic and 1 for manual, im baffled now!!!!!!!!
Old 07-29-2012, 02:12 AM   #10
mopar410
Senior Member
mopar410's Avatar
mopar410's Flag is: United States
But shouldn't they both be balanced for the 360?If one is lighter it shouldn't matter on the crank.It probably has something to do with the flywheel.If you have the auto one and want to try it put it on and see if it shakes and if it does go get the manuel one.i've never heard of 2 different ones either.You sure one isn't for a cast crank and the other for a forged crank?I don't recall a 360 having a forged crank tho.
mopar410 is offline   Reply With Quote
Old 07-29-2012, 11:27 AM   #11
fishy68
Tyr Fryr's Inc.
fishy68's Avatar
Quote:
Good ole Ma making it hard on us, LOL... I don't doubt there's 2 part #'s but for the life of me I can't see how it'd make a difference since all LA 360's require the same amount of offset balance weight.
Old 07-29-2012, 07:12 PM   #12
Robbie2734
Lambcharger
Robbie2734's Avatar
I would think you'd use the balancer you have on it now. I bet those are for externally balance motors, yours is now balanced internally. I had my motor balanced externally and had the flywheel balanced with the rotating assembly at the same time. Check with your machine shop, but I bet you just need to use a nuetral balance flywheel and the existing balancer.
Robbie2734 is offline   Reply With Quote
Old 07-29-2012, 08:52 PM   #13
66plyValiant
Senior Member
theres only one amount of weight for the LA 360 flywheel; now I'm not sure if there is a different tooth count for some of them
the harmonic balancer doesn't matter if its auto or manual as the flywheel for standard is balanced the same as a automatic torque converter
Reply
Search this Thread:
Advanced Search
Display Modes
Similar Threads
Thread Thread Starter Forum Replies Last Post
harmonic balancer bill detamore Small Block Tech 1 02-06-2011 12:21 PM
harmonic balancer Q n00blike Small Block Tech 6 04-13-2008 11:03 AM
harmonic balancer jaxle Small Block Tech 1 01-19-2008 02:08 PM
Harmonic Balancer 66VALIANT Small Block Tech 6 01-31-2007 04:26 PM
Harmonic balancer kork340 Mopar General Discussions 4 06-12-2006 06:38 PM
Fabo Sponsors
Powered by: vBulletin Version 3.8.8 Beta 1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Page generated in 0.19604 seconds with 26 queries
