'73 Sport Amateur Touring!
Graminizer
The "Big G"
Chilliwack, BC, Canada
Hey guys,
I seen someone else on this forum use the "Amateur" instead of "Pro" so I thought I'd steal it.:D I have been a member here for awhile, and I'm finally getting started on my project. It's a 1973 Dart Sport that I picked up 3 years ago. I plan on doing it like a pro touring/cruiser. No need for drag racing for me. It was disassembled when I got it, but I have a '76 parts car that I have as a template. Here are some pics of when I brought it home.
I'm the big guy in the pic!
My son and I prepped and painted the engine compartment. I love this color! Not too concerned about the drips on the frame....I will be repainting it black.....same with the K frame......it's gone altogether!
Would you sell them rear shocks? And you wouldnt happen to have an extra floorshift column layin around would ya?
I used DR.Diff axles for my Dart and they are great. Would definately buy another pair from them.
Should be interesting. Do you have wheel & tire sizes selected?
http://www.forabodiesonly.com/mopar/showthread.php?t=196797&page=3
Check out post #64.
The 1st & 2nd are a 275/45/20, and a 325/50/15 tucked up high. The fenderwell is removed to the quarter.
Next is the nice low tuck that I would like. Then the reality check - showing what is possible without notching the frame. The last one shows measuring to place the wheel center 5" below the frame, which I calculated to be the minimum needed.
Coilovers may get you a little lower as I was leaving 3" for suspension travel.
I picked something special up tonight.......an original, not a repro!
Need to drill for the mounting holes and figure out the size of hole needed in the hood.
Nice project, off to a good start. Keep the pics coming :toothy8:
Looking Good!
The Dodge Dart Sport Was My 1st Mopar And I Miss Mine...
Managed to spend some time in the shop today......continued with the mini tub on the passenger side. Almost ready to tack the wheel well back in place. I just need to make a few more tweeks and she'll be ready.
