[SOLD] Slant six turbo kit
srixon4406
TURBO TOAD
Clarklake Mich
I'm cleaning out the garage of all my unused parts from my turbo build trying to sell as a kit
Modified slant exhaust manifold that's been ported and polished for a aussie big port gasket with a T3 flange
T3 TO T4 adapter with 38mm water gate flange that's been ported and polished $400
38mm Turbonetics delta wastegate $100
Clifford intake with four barrel Carb plate ported and polished using a big port gasket $350
Precision 6765 journal bearing T4 with 68 ar housing its a older turbo with some shaft play but i ran it for mock up and have some video footage if needed doesn't leak any oil! $350
Mallory 4309 boost referenced fuel reg $100
Spectre carb hat like new $125
Holley 750dp blow thru with proform mainbody setup with a single BRPV rebuilt this week with all new gaskets I can give you all the details on the carb if and when needed. $350
All parts are located in jackson mich aera 49234 $1600 obo plus shipping
Some parts and peice will need to be bought and fabricated to make this a complete kit
no calls between 11am and 530pm I work third shift
Aaron
Here's some pics
