Main cap bolt torque - 6.1L SRT8
RealWing
Ontario, Canada
I'm getting ready to install the Milodon oil pan on my hemi and install the new main cap bolt for the pickup.
Does anyone have access to a FSM for the torque value on this bolt?
Thx
These links don't work. I saw a post on the LX forum that seemed to indicate the torque was 28 NM plus 90 deg. but not sure if the value is the same for a non-SRT8 as a SRT8. Hope someone can help
Thx
This information is taken from the Dodge Service manual for the 6.1L Hemi from 2005-2007.
Main Bearing Caps
28 NM plus 90 degrees (you did have the correct information)
Cross Bolts
21.5 NM
Hope this Helps,
Regards,
Joe Dokes
Main Bearing Caps
Cross Bolts
21.5 NM
Hope this Helps,
Regards,
Joe Dokes
^^^^^^ Correct info!
Thx
Some do, some don't. I used these downloads not long ago and they worked fine.
If I could hijack this thread with a related question - apologies to the OP.....
As stated - the TTY #3 Main cap bolt is torqued to 28nm + 90deg.
Is the #1Main cap stud and nut the same - or is there no such thing as a TTY stud/nut?
Main Bearing Caps
Cross Bolts
21.5 NM
Hope this Helps,
Regards,
Joe Dokes
Thanks!!!
Anyone?:happy1:
TORQUE
TORQUE CHART 5.7L ENGINE
DESCRIPTION
N.m- Ft.- In.
Lbs. Lbs.
Block Pipe Plugs 20 - 177
(1/4 NPT)
(3/8 NPT) 27 - 240
Camshaft Sprocket-Bolt 122 90 -
Camshaft Tensioner Plate-Bolts 28 - 250
Coil to Cylinder Head Cover-Bolts 7 - 62
Timing Chain Case Cover-Bolts 28 - 250
Lifting Stud 55 40 -
Connecting Rod Cap-Bolts 21 15 -
plus 90° plus 90°
Turn Turn
Main Bearing Cap-Bolts 27 - -
M-12 plus 90°
Turn
Crossbolts 28 - -
M-8
Cylinder Head-Bolts
M-12 Bolts
Step 1 34 25 -
Step 2 54 40 -
Step 3 Turn 90° Turn 90°-
M-8 Bolts - - -
Step 1 20 15 -
Step 2 34 25 -
Cylinder Head Cover-Bolts 8 - 70
Exhaust Manifold to Cylinder Head 25 - 220
Flexplate to Crankshaft-Bolts 95 70 -
Flywheel to Crankshaft-Bolts 75 55 -
Front Insulator-Thru bolt/nut 95 70 -
Front Insulator to Support Bracket
-Stud Nut (4WD) 41 30 -
-Through Bolt/Nut (4WD) 102 75 -
Front Insulator to Block-Bolts 95 70 -
(2WD)
Generator-Mounting Bolt 55 40 -
Intake Manifold-Bolts Refer to Procedure
Lifter Guide Holder 12 - 106
Oil Pan Bolts 12 - 105
Oil Dipstick Tube 12 - 105
Oil Pan-Drain Plug 34 25 - Oil Pump-Attaching Bolts 28 - 250
Oil Pump Pickup Tube - Bolt and Nut 28 - 250
Rear Seal Retainer Attaching Bolts 15 - 132
Rear Insulator to Bracket- 68 50 -
Through-Bolt (2WD)
Rear Insulator to Crossmember 41 30 -
Support Bracket-Nut (2WD)
Rear Insulator to Crossmember- 68 50 -
Nuts (4WD)
Rear Insulator to Transmission- 68 50 -
Bolts (4WD)
Rear Insulator Bracket-Bolts 68 50 -
(4WD Automatic)
Rear Support Bracket to 41 30 -
Crossmember Flange-Nuts
Rear Support Plate to Transfer 41 30 -
Case-Bolts
Rocker Arm-Bolts 22 - 195
Spark Plugs - - -
Thermostat Housing-Bolts 28 - 250
Throttle Body-Bolts 12 - 105
Transfer Case to Insulator 204 105 -
Mounting Plate-Nuts
Transmission Support Bracket- 68 50 -
Bolts (2WD)
Vibration Damper-Bolt 176 129 -
Water Pump to Timing Chain 28 - 250
Case Cover-Bolts
Thks Joe...so I can assume the stud nut would be 28nm + 90 degreees also.
Checked my manual again just to make sure. Once you torque the nut on the stud down, you will then place the oil pick up bracket and place another nut on top and torque that nut to 28 NM as well, but don't do the additional 90 degrees.
Here's a pic of the torque sequence from the manual.
Regards,
Joe Dokes
Regards,
Joe Dokes
Thats great info - thanks Paul :prayer:
