My new led dash lighting.
younggun2.0
federal way, wa
got the new LED lights wired up and working on the dash. they are super bright and look pretty cool i think. what do you guys think?
here is a picture of the light bulb. I got 10 of them for 11 bucks shipped. they have a light on each side and 1 on top. they send light in a full 360 degrees. they dont get hot and they take less power to run than the stock bulb. these suckers are bright. you cant look straight at them when uncovered. they make you see dots ha ha ha
at first i was thinking it looked a little fast and furious but then i was like "**** it, those look awesome". finally i can see the faces of my guages in the dark.
How difficult was it to swap over?? Thinking bout doing the same with dads 67 cuda. Looks great by the way!! In my opinion, lit up the way they should be.
was as simple as unplugging the old bulb and plugging in the new ones. i just had to rewire mine because i got rid of the stock gauge cluster.
amazon.com i just searched for 3 194 base led lights. i did some research and asked for dimensions of the bulbs prior to ordering them. i got them from a place called JTECH.COM
I got mine on ebay motors they werent much on 67 barracuda when you can tell me how to do the inside gages from the performance indicator over let me no. The outside ones were easy but cant figure out the rest and I dont want to pull the dash. If you have the answer pm me.
The odometer says two miles.How were those 8 passes,lol.:burnout:
If you're asking bout replacing the dash bulbs without removing the dash, you can probably reach a few of them fairly easily, but to make it easier take the drivers seat out. It will give you more room to crawl around under the dash. Best bet to replace them all is to remove the instrument bezel....it can be done, but it also can be a *****!
Cool, great price too. do they by any chance happen to be available in different colors?
yes, pretty much any color you want. they even have pink, if thats your thing. ha ha ha. even just going to the clear ones would be a huge improvement.
Cool! Stickin with orig factory gauges. Gonna run it by dad and see what he says.
Thanks!
if you can find out what the # is for the stock dash bulbs you can just look up that # with the word LED and they make them im sure. i found over a 100 pages of bulbs.
Have them in my Duster and rock crawler in blue, got mine at superbrightleds.com.
