[SOLD] 78 440 (complete)
dustinmoran91
muskogee oklahoma
78 model motor home 440, standard bore and crank, has crosshatching in the cylinders so im assuming its a low mileage motor. bearings look good and no excessive play anywhere. i coated it with wd-40 to prevent any rust or anything like that. i wouldnt be afraid to throw a small cam in it and run it as is. has complete 452 heads and a stock intake. has rear sump oil pan and factory windage tray. no water pump housing or distributor but i do have a holley 750 that can go with it. located in 74403 oklahoma asking $550 with the carb and everything.
Hate to bump so soon but just found out that my dad was 4 months behind on the mortgage payment before he left and they go into the foreclosure process after month 5 so i gotta come up with $2500 fast lol
Sorry I don't have any trades or cash. So I can't buy but I am sure someone will. it's a good price.
Sorry i dont check this very often, i would tradr for an 8mm mauser, two 91/30 mosin nagants, two 440 round cans of 7.62x54r, a 1000 rounds of 8mm for the mauser, .223/5.56 ammo, ar-15 magazines, .45 auto ammo, 7mm magnum ammo, a reloading press, .22lr ammo, a bull barrel remington 597, a bull barrel mossberg 22vr, a bolt action .223, .308 ammo, a set of ar500 armor plates, a sig saur mosquito with threaded barrel, an ATI mauser 98 scout stock and some cash, 9mm ammo, or if you have another rifle or pistol you would trade i can add cash on my end no problem, all of the stuff i listed is in the $350 or less range. I think the 597 and 22vr are the two highest being close to $350 but the rest should be under $300. I have a lot of this stuff priced out already and if you want you can message me a cash offer because i know how much of a pain transferring firearms can be when not in person. Hope this helps. If you dont have anything like this message me and ill talk to you about maybe lowering the price since you said it was a gift
