Connecting a GM HEI module to the dizzy
2-66 Cudas
West Newton, PA
I have 2 diagrams from 2 different members showing conflicting information on this subject. One shows B going to the + side of the coil and C going to the - side. The question is with the W and G connections. I have a black wire coming from the distributor into a moulded plug to a female end and an orange wire into the same plug with a male end. This diagram does not designate what color to W or G. The other one, according to the ground location, has W to the - end and G to the + on the coil. B is going to the male C is going to the female on the distributor. CAN SOMEONE CLEAR THIS UP? I have everything mounted and wired, just need to know what plugs to what!!!
This is correct looking down at the top of the module. The distutor connector is hooked showing the bare male terminal of the connector as shown. I guess you know distributor pickup polarity is important as it affects rotor phasing
Or................
