Mopar mopar forum
 HOME  FORUMS   FABO STORE   MEMBER PHOTO GALLERY  CHAT  MEMBER CLASSIFIEDS  MOPAR VIN DECODER   REGISTER
 VIDEO GALLERY  NEW POSTS  TODAYS POSTS  SEARCH  CALENDAR  B BODY MOPAR FORUM  E BODY MOPAR FORUM
Go Back   For A Bodies Only Mopar Forum > Automotive Technical Forums > Body / Interior / Trim
best way to fix rust around rear window
Thread Tools Display Modes
Old 06-09-2007, 02:38 PM   #1
racyroy1
Senior Member
racyroy1's Avatar
Hello all:
I have a 72 scamp with alot of rust around the rear window at the bottom corners and the flat part of the fender by the corners. My question to all of you is what is the best way to repair? Find a donor car and use its corners, or shape some new steel? I'm kinda new at the entire removal and replacement of steel. If the doner car is the way to go how much do i cut out and if the new steel is the way do I have a professional do it. Now that ya kinda know what i'm looking at, any and all info would be appreciated.
thanks
kevin.
racyroy1 is offline   Reply With Quote
Old 06-09-2007, 02:59 PM   #2
ValiantMike
Senior Member
Kevin, if areas are flat you can just cut out and use flat sheet metal to replace. If rusted areas are angled with patterns in them it would probably be best to cut that area out of a donor car. Cut off more than you need from donor car to be sure you have enough to replace your rusted area. You can always trim piece down once you have it. Sometimes if rust is near a factory seam, it may be better to go to the seam with replacement metal. You should take some pics and post them here. There are quite a few body people here that can better advise you if they can see whats needed. Mike
ValiantMike is offline   Reply With Quote
Old 06-09-2007, 03:09 PM   #3
racyroy1
Senior Member
racyroy1's Avatar
hey thanks Mike.
Here are the areas that are in question.
Old 06-09-2007, 03:20 PM   #4
AdamR
Admin & Site Founder
AdamR's Avatar
AdamR's Flag is: United States
Those are going to hard spots to fabricate. Your best bet is to fins a donor car to cut the metal from. Look for a car that doesnt have a Vinyl top otherwise you may end up with more of the same.
AdamR is offline   Reply With Quote
Old 06-09-2007, 03:26 PM   #5
ValiantMike
Senior Member
I agree with Adam. Take your grinder and clean area around rust to be sure where it ends, and then cut a couple of inches larger from donor car and then taking your time, trim new piece to fit properly and attach it. Do you have a welder and welding skills?
Old 06-09-2007, 03:44 PM   #6
racyroy1
Senior Member
racyroy1's Avatar
once again thanks a lot
yes i do have a mig, hobart handler 120 with gas and in my own mind i'm the best welder in the world but most people, especially the blind, say otherwise. And here is the funny thing I have a donor car outside but it is in better shape than the one i'm working on. I bought it as a donor but?
kevin
Old 06-09-2007, 03:46 PM   #7
AdamR
AdamR's Avatar
It may be the way to go if its in better shape. Its all ways best to start with as little rust as possible.
Old 06-09-2007, 03:56 PM   #8
360scamp
Pissed off senior member.
360scamp's Avatar
360scamp's Flag is: Ireland
Any pics of the "donor" car?
Do they still have the mopar swapmeet at the Grahm fairgrounds or is that the one that was moved out to Carnation?
360scamp is offline   Reply With Quote
Old 06-09-2007, 04:37 PM   #9
racyroy1
Senior Member
racyroy1's Avatar
yea that it is but it's a lot easier to fix less than more. The one thing that has me wanting to fix the one with most of the rust is that I have every piece of documentaion that was ever generated with the car, including the white paper fob that came on the original keys which i have and still start the car to this day. I have a little note pad from 1972 where the original owner started taking notes and even documented her first tank of gas at 35 cents a gallon. I have everything in between also.
Heres the pics of the donor car
Hmmmmm decisions decions.
Old 06-09-2007, 04:39 PM   #10
racyroy1
Senior Member
racyroy1's Avatar
and yes as of last year I believe they still have the swap meet, I live just east of the fairgrounds behind gundies
Old 06-09-2007, 04:55 PM   #11
ValiantMike
Senior Member
Kevin, you should thoroughly check bodies on both cars for rust and damage. Floors, lower doors, fenders, quarters, sub-frames, trunk, etc., anywhere and everywhere. Then compare drivetrains, interiors, options, etc., and then try to make a sensible decision as to which would be best to fix up. To tell you the truth, the donor car you have looks to be in pretty good shape, from looking at the pics. Shame to have to chop it up. Like you said, decisions, decisions. Mike
Old 06-10-2007, 08:01 AM   #12
abodyjoe
Senior Member
abodyjoe's Flag is: United States
Send a message via AIM to abodyjoe
go cut the pieces out of a donor car.. it will be alot easier that way because all the bends are alrerady there and the shape you need.....
abodyjoe is offline   Reply With Quote
Old 06-10-2007, 08:05 AM   #13
abodyjoe
Senior Member
Old 06-10-2007, 08:09 AM   #14
AdamR
AdamR's Avatar
Thats the way to do it.
That Scamp looks pretty clean though. I would take clean sheet metal over paper work anytime.
Old 06-10-2007, 09:24 AM   #15
ValiantMike
Senior Member
Great pics abodyjoe. Exactly what he needs to see. Yea Adam, I would agree, unless car is a limited number, highly optioned rare model, I would definitely choose the best body over paperwork. JMO, MIke
Old 06-10-2007, 09:57 AM   #16
abodyjoe
Senior Member
Quote:
me three....
Old 06-10-2007, 12:49 PM   #17
racyroy1
Senior Member
racyroy1's Avatar
thanks mike, valiant joe, adamr and abodyjoe it's what i needed to push me over the edge. I also would've had to cut all the sheetmetal out of the trunk and move it over to the project car and it was bugging me since the doner was in such good shape. I think now I'll just move the interior over and whatever else needed and cut my losses. Once again thanks guys
kevin
Old 06-10-2007, 01:16 PM   #18
ValiantMike
Senior Member
Kevin, you can part out the car you don't fix up. Plenty of people are looking for all kinds of parts for these cars. Maybe place an free ad on here after you take what you want. It'll help pay for parts you'll need. Mike
Old 06-10-2007, 02:07 PM   #19
EvilScamp
Senior Member
EvilScamp's Avatar
Send a message via Yahoo to EvilScamp
Quote:
Originally Posted by abodyjoe
me three....
Me four!
EvilScamp is offline   Reply With Quote
Old 06-10-2007, 05:41 PM   #20
racyroy1
Senior Member
racyroy1's Avatar
yep sure will thanks again guys
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
looking for the rear window sheetmetal wireweld Body / Interior / Trim 6 04-09-2007 03:43 PM
""65" Valiant interior door panels & rear window tray. PowerWagon896 Body / Interior / Trim 1 04-03-2007 09:18 AM
Rear Window Gaskets carcrazyguy General Discussion 5 03-01-2005 11:21 PM
option codes. AdamR Tech archive 0 10-28-2004 03:41 PM
FABO SPONSORS
Limited Edition FABO T-Shirt
Mopar T Shirt
LAST CHANCE! Get Yours Today!
Dales Cuda Shop
Rosevilla Mopar Parts
Charger Specialties
Performance Suspension Technology
Inertia Motorsports
1960-1976 Plymouth Valiant - 1963-1976 Dodge Dart - 1964-1969 Plymouth Barracuda - 1971-1976 Plymouth Scamp
1970-1976 Plymouth Duster - 1961-1962 Dodge Lancer - 1971-1972 Dodge Demon - 1971-1981 Valiant Charger (Australia Only)
air suspension | suspension parts
Powered by: vBulletin Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.23457 seconds with 12 queries
