vin # from fender tag
DUSTER2078
Member
indiana
is it possible to get the VIN # from the fender tag? i have a 1970 duster drag car that doesnt have a VIN #. i am trying to do some research on it and didnt know if it was possible to backwards trace the VIN #.
the last 12 as in how you read the vin bottom to top left to right, or last 12 as in how they are on the tag?
post a pic and i will get you all the info off it.
or the post the last 13 numbers/letters
they are read left to right. here is mine , my VIN is the bottom right , 13 spaces
some of those are hard to read so i may have entered the codes wrong
VS29:
Plymouth Valiant,Duster
Special
2 Door Sports Hardtop
H0B 340 275HP 1-4BBL 8 CYL
1970
Dodge Main, Hamtramck, MI, USA
153670: Sequence number
E55: 340 cid 4 barrel V8 275hp
D21: 4 Speed Manual Transmission
FK5: Exterior Color Dark Burnt Orange Metallic / Deep Burnt Orange Iri
L6X9: Trim - Low, Vinyl Bucket Seats, Black
TX9: Int. Door Frames/Black
A10: Build Date: October 10
005069: Order number
FK5: Top Color Dark Burnt Orange Metallic / Deep Burnt Orange Iri
A01: Light Package
A62: Rallye Instrument Cluster Package
G55: Outside LH Remote Painted Racing Mirror
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
N41: Dual Exhaust
N35: Top Color
R11: Radio Solid State AM (2 Watts)
V6X: Longitudinal Stripes, Black
V8X: Tranverse Stripes, Black
Y05: Build to USA specs
EN2: End of Sales Codes
That was a nice car when it was built!!!!!!!!!!!!!!!
VS29:
Unknown
HOB: Dodge Main Hamtramck, MI, USA
353670: Sequence number
FK5: Burnt Orange
TX9: Black Int. Door Frames
005869: Order number
FK5: Burnt Orange Top Color
A01: Light Package
C55: Bucket Seats
N41: Dual Exhaust
N35: Top color
V5X: Body Side Stripes, Black
Y05: Build to USA Specs
H0"5"
some of you guys are getting lazy... it's a B
I think it's this color originally
now with that said, does the core support and quarter panel numbers match the fender tag vin? If so, then you have put the body together with the fender tag.
the top lip of the core support left side. There might be a sticker over it and sometimes it is painted over. Normally you can feel under the lip for the indentation. Place a piece of paper under it and get a rubbing of the number the last 6 of vin should be included in those numbers. The other vin is normally on the left quarter panel on the trunk seal lip again feel under it and get a rubbing.
Sometimes cars get in accidents and one of these numbers are not there (replacement panel) or different (panel from another car).
There are other places to look also but these are the easiest to find. If they do not pan out then we will venture down that road.
The rear numbers on a Duster are not usually in the trunk rail area. Look on the package tray, driver side, between speaker hole and window channel.
Ok I will check it out. It was only driven for 2 years I was told when I bought it. It was turned into a drag can and has been since 1972.
New here so just wondering is anyone can decipher these vin tag numbers . When i figure out how to post a picture i will ( or if anyone can explain how to do it )
END
M21, M25, M31, M43, R11, V5X
V1X , U F11, G33, H51
GT2, H2X9,TX9, C14, 219141
E44, D31 LH23 G1R 181410
Window VIN # LH23G1R181410
I,m just starting to restore it now
All I know is 71 dodge dart , 318
LH23:
Dodge Dart,Demon
High
2 Door Hardtop
G1R: 318 230HP 1-2BBL 8 CYL
1971
Windsor, ONT, CAN
181410: Sequence number
E44: 318 cid 2 barrel V8 230hp
D31: A904 3-Speed Auto Trans.
GT2: Tan Poly Exterior Color
H2X9: Trim - High, Vinyl Bench Seat, Black
C14: Build Date: December 14
219141: Order number
V1X: Full Vinyl Top, Black
U: USA Specifications
F11: 46 Amp Alternator (std with AC)
G33: LH Remote Racing Mirror
H51: Air Conditioning with Heater
M25: Wide sill moldings
M31: Belt Moldings
M43: Grille Trim Moldings
R11`: Unknown
END: End of Sales Codes
Is it tubbed? If it is, it sounds like a car that used to be local to where I live in NC. If it's the same car, it got tubbed in 1975 or 1976.
