I have a new in box A-Body radiator. Not sure of the brand. The inlet is bottom right as a 70 and up uses. It will fit earlier A-bodies but will require a water pump and lower hose swap. Fins are nice and straight and no dents in tank. Has auto tranny cooler built in. Never used. $205.00 plus ride. I'm in the Houston area. This is a 2 row radiator.
Thanks FABO
Thanks FABO
