Big Block Swinger from Oklahoma
Sideways
Active Member
Marlow, ok
I have been working on getting this ready for the power tour ( 2013 ). I have the engine and tranmission mounted, frame connectors in and a narrowed 9". it should be back up and running in 2 weeks. I cna't wait to take it back out. the old slant 6 just was not cutting it.
I have several big block chevy's. my other toy is a 496 in a Mazda pickup. if i ever want to slow it down i will put a Dodge back in it. just kidding. I just have lots of parts for the chevy. and i was told it could not be done. I am very hard headed
I am just messing with you guys. I have got alot of help from here. between my and my racing buddy we have 7 bbc's and 15 power glides. I pulled this one out of my race car and hated to just let it sit under the bench. I love the old Swinger body style but went with what I had on the engine and trans. this is just the Sonic cruiser so me and the family can run around town and mess with the kids at the stop lights.
I will see you in Memphis on the 3rd of June I believe, Power Tour 2013, welcome :glasses7:
You will like the raceway there and good luck and get some pictures of the
Tour for us if you can, we have a few long haulers here :cheers:
I've had a couple of sacrilegious thoughts of sticking a turbo'd 4.6 4V/4R75 in my '72 Scamp...biggest reason is kinda like the OP, I have access to them for a little bit of nothing. The 383/727 will still very likely be the engine/trans of choice, but I won't rule out the possibility of dropping a forcefed modular between the fenders.
That's going to be quite the radical upper heater hose you are going to need.
If it's a race engine, why didn't you go with headers instead of log manifolds that would choke that mill off big time?
on the manifolds it is just a cruiser and cast iron maniforlds won't leak and I have enough up keep on all the vehicles at my house. If it helps my wife drives a new charger. I started putting in the new interior last night. carpet, seats, package tray, and dash pad cover. it sure looks better than the white that was in it.
I see the problem and it's easy to fix. Sell all the chebbie stuff and buy some good ole Mopar stuff to throw in there. I think a turboed /6 would be faster. I always hear chevy is cheap, but I haven't seen that to be true if you are building a good engine..especially a BB. A friend always told me never rap a BB chevy past 4500 if you want it to stay together. I guess that's why there are so many aftermarket parts. I think I would sell a cheap 454 w/glide and there should be enough to buy an expensive 440/727, aluminum intake, headers, and a shift kit for the Dart.
If it helps any, my first thought was ford when I saw you downgraded. It's your car, so have fun. It does fit well and look nice, just make sure people know it's a chevy when you get spanked. :bootysha:
Now that I made fun of you, could you tell us about your subframes and give a couple of picks where they connect. They look like 2x2 tubing, but I don't see any proplems with hitting the floor board.
the sub frame connectors are 2 x 3 x 1/8 tubing. I found an article on big block dart. I cut them to 53" and contourted them around the spring boxes in the rear. I did not use the plates in the front like the article had pictured my frame has a lump formed in it so I had to trim the front tube on the drives side around that. since mine is a 74 I did not have to move the e brake cable or anything. it was only $20 worth of tubing and a few hours work. I will get better pictures tonight. And for the black engine bay I have a pint of Frosty green that will cover the old nasty inner fenders and fire wall when the engine comes out this week so i can rebuild the transmission.
http://www.bigblockdart.com/techpages/connectors.shtml
