Dusterdude72
IN MOPAR MUSCLE MAGAZINE
Hey guys, I ran into this issue a couple months back but put it on the back burner until I was closer to having the car on the road. its a 72 duster,small block, 904 trans,transgo tf2 shift kit ( I did not use the parts to make it full manual ...just the shift kit). I have a stainless braided throttle cable (new and adjusted in), the bracket that holds both it and the kick down cable. And I have a stainless braided kick down cable aswell.
With the kickdown disconnected and just the throttle cable and 2 return springs connected I have a nice feeling pedal. not to wishy washy but not firm either....feels great. But as soon as I hook the kick down cable to the car....its like pushing on a brick wall when I push the gas pedal ( it moves ...but somethings not right...it takes to much pressure to use the gas pedal with it hooked up).
My cables are all routed correctly as per lokar instructions (and it has the bracket mounted at the tailstock pulling the kickdown lever toward the rear of the car.....so its not an issue of being on backwards).
The cable is routed nicely with no sharp turns or kinks or bends and is away from exhaust also.
I can grab just the cable itself with my fingers and slide it in and out of the cable housing freely so its not binding in the housing.
I adjusted the kick down to lokars instrucktions ( held throttle wide open, then with pliers pulled the kick down cable all the way out as far as it would go and then locked the set screw in place.....basically full throttle is full kick down and closed throttle is no kick down).
I can get under the car and manually move the kick down lever It moves freely ...not rusted or stiff and it has some resistance to it...feels like its spring loaded.....but even what resistance I feel at the lever by hand doesnt seem like as much as the resistance I feel at the pedal that requires so much effort to push.
Anyone ran into this problem before?.....whats the fix? I have been racking my head all day trying different tweaks and I cant get a pedal feel that does not require the hulk to be my driver LOL.
Also another question. I have heard some guys say you cant run without the kickdown hooked up and some guys say you can run without it hooked up. I heard its an issue with line pressure....my question is.....does the issue only come into play when the vehicle is in "D" and the shifts are automatically controlled?....if so....can it be manually shifted 1-3 3-1 without the kickdown cable hooked up and without an issue.
why i ask is....my dad said when he was younger he had a duster and put headers on at which point he couldnt get the linkage to clear so he unhooked it and down shifted manually for kick down from then out and never had any issues with the trans acting up or burning up.
anyhow thanks in advance guys. Hopefully its a simple fix because this car keeps tossing curve balls at me the closer to the finish I get lol.
sorry for the long post, Thanks
