68383GTS
Sharktooth grille very nice shape,better than most.Small crack rh bottom,small crack rh top,top corners cracked where the headlight bezels fasten too.I have the small pieces that are cracked off the grille.The teeth are are there and none are cracked or broken.The grille looks to be mostly original paint except where someone painted the upper and lower section black.The trim that goes the length of the grille on the upper and lower section is beat up some.New parking light sockets.
$750.00 plus shipping
Located in Illinois
Located in Illinois
