[FOR SALE] 8.25 rear w/ 3.90 gears out of 73' Duster
dpmalibu
Hatboro,PA
Just like title says I have this rear w/ new 3.90 gears. It is an open diff w/ the spider gears welded. You will need to put a new carrier in it to use it on the street. It was in a dirt track car. Only has a couple of races on it.
I also have a pair of leaf springs (5 leaf) $75
Rear $175
located in Hatboro,Pa
Any chance you can sell me the ring and pinion and the bolts for the rear end cover? Just bought a Auburn center section and need the gear so I can put it together.
I might do that. Let me see if there is any other intetest in the whole thing. If it doesn't go by the weekend then I will take it apart
