gerty
I have this Valiant roller for sale that I will never get to. It was an ex bracket car so the interior is bare except for a pair of Mustang buckets just thrown in.
The floors were "fixed" with sheet metal, rat rod style, lol. The trunk is solid with only a hole cut out where the fuel cell sump was. Other than a very small bubble on each lower quarter there are no rust issues on the rest of the body that I have noticed. It's not beat up and all the glass is there.
The wiring is missing, I was planing on using a complete harness, gauge cluster, steering column etc. from a '73 Duster. That way you get elect. ignition, voltage reg, alternator plugs all in the harness, Also a locking steering wheel and a key in the column etc.
The slant k member is still there, but the left motor mount was removed for big block clearance. Mounts for big block elephant ears are welded in. The rear has been mini-tubed but only installed with sheet metal screws, would be better to weld them in. The rear in the car is just a 7 1/4 to roll around with.
Fenders, bumper with brackets and grill are here but not in the first pics. I will try my best to get more pics loaded tonight.
There is no title for the car. Bill of Sale only. I had planed to title it from one of the online companys but never got around to it.
There are 4 new Cooper Cobra 225-70-14s with zero miles on steel small bolt rims on it, I could let go with it or bring yours to swap out for loading.
Asking $1000 without wheels and tires. $300 for wheels and tires.
Located in Burkesville Ky 42717
