Pertronix kit for HP 273 dual point
Hipo65
Yeah I'm "That Guy"
Lincoln Nebraska
Hello guy's just tryen to get some ideas on converting my stock presto lite dual point dizz to a pertronix kit or somthing like it. I want to keep the dist in service due to it beeing o.e. & for the advance cure allready in it. Has any of you done this? i talked to pertronix they said they dont have a kit for my dist.? what the diff between mine & a 340 presto lite? I know when i went to get new points & cond for it that was fun it takes napa echlin cs721a points. They keept tryen to sell me 720a points but they were backword's for my dist. Thanks for any help in advanced:cheers:
I did it and it worked good. I had to send my distributor to Pertronix and they found a kit for it. I believe it was for a late 50's Hemi dual point. I'll post the kit number here as soon as I can find it. tmm
That's kinda strange since they have one to fit the Prestolite distributors in the early Hemis.
Thank you Thank you Thank you Toolman!!! I knew there had to be somthen for it. ive been fallowing yer Chager 273 build up & the top shelf info you put out. I just ordered that same e-4 cam for my hipo (ill pull it this winter & freshen er up) hows the low end with it? i.e. below 2k? again thank you!:thumblef:
Thanks' again toolmanmike! i checked my local speed shop in town, & sure enoph they had one in stock. (speedway) droped rite in & runs great. seems to be more stable through out the whole rpm range. :cheers::cheers: Thank you!
