[SOLD] 1974 plymouth duster
stanzilla
Member
crete
Rating - 0%
0   0   0
74 duster clean body,door jams rocker panels rear quarters are clean,original 360 v8 car,full interior with bench seats that are clean,3inch full exhaust with dyno max mufflers and with h-pipe, 83/4 rear end 742 case dont know gear size, ajustable pinion snubber,mild 360 flat top pistons crower solid cam, edelbrock rpm heads, pro comp rockers,proform electric water pump,becool radiator,new 10inch 3500 stall converter,727 trans,i have clear title asking 6,500 or best,pm me for any question i can send more pictures if needed thanks.located crete ill.
me likey , Im gonna show this one to the wifey, see if she might let me get a closer look at this one
is it a column shift car or did you install a ratchet shifter?
