[SOLD] Complete 360-408 stroker engine
physixx
Edison, NJ
BLOCK IS .030 OVER
CLEANED, BORED, HONED AND NOTCHED FOR ROD CLEARANCE
CASTING DATE 12-4-75
NEW KB .030 OVER FORGED PISTONS
NEW TOTAL SEAL .030 OVER MOLY RINGS
NEW INTERNALLY BALANCED SCAT CAST STEEL CRANK STD/STD
NEW SCAT I-BEAM RODS
NEW CLEVITE CAM, ROD AND MAIN BEARINGS
NEW BRASS EXPANSION PLUGS
NEW SUMMIT .480/.480 LIFT HYD. CAM AND LIFTERS # SUM-1798
FINNED ALUMINUM VALVE COVERS PAINTED WRINKLE BLACK
NEW MELLING HV OIL PUMP AND PICKUP
NEW KEVKO EXTRA CAPACITY OIL PAN AND PICKUP
NEW POWER FORCE HARMONIC DAMPER
NEW CLOYES FULL ROLLER TIMING SET
"X" HEADS W/BRONZE GUIDES, CRANE SPRINGS
HARDENED VALVE SEATS AND NEW STAINLESS 2.02/1.6 VALVES
HEADS HAVE BEEN POCKET PORTED
FACTORY TYPE ADJUSTABLE ROCKER ARMS
CUSTOM PUSHRODS FROM SMITH BROTHERS PUSHRODS
MSD BILLET ALUMINUM DISTRIBUTOR #8534
EDELBROCK TORKER II 340 INTAKE #5076
REMANUFACTERED WATER PUMP
ACCEL WIRES AND NEW CHAMPION SPARK PLUGS
LATE STYLE TIMING COVER
COMPLETELY ASSEMBLED & PAINT HEMI ORANGE
$4,500.00
plus shipping from Edison, NJ 08820
I can also help with shipping arrangements,
crating and delivery to truck terminal for a small fee
This engine is fresh and is still on the engine stand. All
that is needed is a carburetor.
With the dished piston, open chamber X head, and the Fel Pro blue head gasket, the CR would be about 9-1.
Ken
I'm very interested if still available. I'm right across the river just outside of Philly for quick sale. Please get back to me. Tax refund, mini tubed valiant just need the motor.
