1972 Scamp, my regular cruiser
57dodged100
Albany, OH
I'm finally getting around to making a project page. So I plan on loading a bunch of info about this car over the next few days.
What: '72 Scamp with slant six, 36k original miles.
Why: I wanted an older Mopar to drive on a regular basis.
I restored a'57 dodge d100 but can't haul the family in it. Plus, I built a show truck and don't drive it regularly. The goal was to acquire a cruiser that would allow the family to join me and not be so nice that I'd hesitate to drive it.
This is what I drove home.
The wheels were too wide and were rubbing in the back. I sold them and painted the original wheels that also came with the car.
Then added trim rings
I found the build sheet when I remove the backseat to fix quarter glass that wouldn't roll down.
Am radio wasn't enough, so I bought this bluetooth speaker and mounted it to a no-slip GPS dash pad. I stream music from my ipod with no wires.
The engine looked pretty good. I replaced the washer bottle and fittings.
Mechanically, I converted to electronic ignition with pertronix ignitor ii and coil. I put in NGK plugs, and new plug wires. Adjusted the valves, it runs nicely.
I drove the car 3 to 4 times a week during the summer. One of the torque converter tabs broke off and that led to a converter replacement and a transmission service.
Once the cold-weather set in I started to do some cleanup.
Added some wire loom
KeganB sent some grill pieces and I repaired it, but I haven't painted yet. Too cold.
My intentions was to NOT paint the car for a few years. However, my friend who owns a body shop decided to retire soon. It would cost me twice as much for anyone else to paint the car, so I decided to have it done before he retired. The car has virtually no rust. There is one dime sized piece on the rocker on the right and a few pin hole spots behind both rear wheels. I have pulled everything that needs to pulled: bumpers, trim, mirror, antenna, grill, etc.
I knew there was a surprise waiting under the vinyl top
The joint between the roof and quarter panel had OEM plastic filler
He will spot blast this area and then repair.
The plan is to paint the top black rather than replace the vinyl.
That is nice. Painting it the same color I hope, I like that color. I used to have a 72 Scamp, I'd love to have another one.
Nice ride! I'm thinking of trying to find a /6 Scamp for a daily as well. I'll be watching this thread as well for ideas.
Great looking car. You have a jumpstart based on the condition. I do like the color but it will be a real looker with a black top.
Thanks for comments FABO!
Yes, I'm keeping it the same color, GF3 - medium green metallic.
When I bought the car it was only getting 13mpg. After a tune up, I added 2.25 single exhaust with a glasspack. Now it gets 18mpg around town and 23mpg on the highway.
wow that actually sounds pretty bad ***! I had a slant in my 71 Scamp with a small Monza muffler on it and it sounded deeper but not like that. That's a real clean Scamp! Can't wait to see it painted.
Here are a couple of pics of it as it sits now, waiting to go for paint.
I'm ALMOST done scraping the vinyl adhesive off. Goo Gone and a razor blade does a nice job, but it is a slow process.
I plan on adding a gloss black tail stripe. I think the black wheels, stripe, and black roof will give it the styling I like.
I also had these decals made to put on. The large ones will be placed on the front fender, where the Valiant and Scamp emblems were removed.
I made the smaller ones to go on the quarter glass, but I'm not sure I will use them. It might "bee" too much!
So I stole a few hours from the family today, and got a lot accomplished.
Detached the rear bumper bracket and then painted the bracket with Eastwood rust encapsulator
So my bumpers were in good shape, but once the car is repainted this month the bumpers would have looked dingy. So I bought 2 AMD bumpers for the cost of having one rechromed. Plus, I hope to sell my originals to recoup some of my cost.
My old ones:
New ones:
I wanted to protect the rear side of the new bumpers so they don't rust. So I used self etching primer and silver paint on the underside.
I also had a chance to finish painting the grill. Remember, it had a broken fin that was repaired.
Cleaned, primed, black, and then clear. I think the black grill will fit the theme: black also on wheels, roof, and tail stripe.
Looks great! I really like the grille.
I like what you're doing with the car.
Just don't go overboard on the car and you won't have a daily driver anymore like your others!
