[SOLD] Complete, fresh 360 engine
physixx
Edison, NJ
BLOCK IS .030 OVER
CLEANED, BORED AND HONED
BLOCK HAS BEEN LINE HONED
CASTING DATE 7-7-87
KB-190 HYPEREUTECTIC SMALL DOME 10.0:1 PISTONS
NEW HASTINGS MOLY RINGS
STOCK NODULAR IRON CRANK .010/.020
STANDARD 360 RODS
NEW CLEVITE CAM, ROD AND MAIN BEARINGS
NEW BRASS EXPANSION PLUGS
NEW SUMMIT .480/.480 LIFT HYD. CAM & LIFTERS #SUM-1798
NEW MELLING HV OIL PUMP AND PICKUP
OEM CAR TYPE OIL PAN
FACTORY CAST CRANK 360 HARMONIC DAMPER
NEW CLOYES TRUE ROLLER TIMING SET #9-3103-5
"J" HEADS WITH OEM 340 HP SPRINGS
2.02/1.6 VALVES AND BRONZE VALVE GUIDES
STOCK TYPE ROCKER ARM-PUSHROD SETUP
MP POLISHED ALUMINUM VALVE COVERS
LATE STYLE TIMING COVER
EDELBROCK TORKER 340 INTAKE #2700
REMANUFACTURED WATER PUMP
FACTORY ELECTRONIC DISTRIBUTOR W/NEW CAP & ROTOR
ACCEL WIRES AND NEW AUTOLITE SPARK PLUGS
COMPLETELY ASSEMBLED & PAINTED HEMI ORANGE
$2,850.00
plus shipping from Edison, NJ 08820
I can also help with shipping arrangements,
crating and delivery to truck terminal for a small fee
Will this run on pump gas with 10:1 pistons and the open chamber heads?? I'm guessing in the 325-350 HP range??
The guy that I got them from said that they were older Mopar Performance valve covers but I thought that they would have the MP logo cast into the middle. Other than that, I don't know but they look great.
Ken
i have a set of those covers, but not polished. I think they were just a generic cover made by a company like Cal Custom or something in the late 70's to 80's. They sometimes have weiand or holley in the center i think??
$2400? Reasonable offer? Would like to sell to make room for the next project.
Ken
That's a good deal for someone, cant believe it hasn't sold.
Left mouse click on my screen name and click on Start a conversation. That's the new PM
