[FOR SALE] Dyno Simulator Printouts
RustyRatRod
Caput villa stultus
Georgia
I have had an influx of requests for Desktop Dyno numbers. I would like to provide to those who do not have any programs. I will "build" you a simulated dyno run for your engine combination. I can get pretty close with this the more information I have from you. I can even input cylinder head air flow information from your flow sheets if you have them, but the program's default for cylinder head porting is pretty good.
Things have been rough for Kitty and I the past year or two. If yall will help us, I will help you. I think this is a fair deal for those who might not want to spend 50 or more bucks on a dyno simulator program.
So here's the deal. For $9.95 mailed to you I will send you a printout of your engine combo. This includes several pages of information, including horse power and torque graphs, charts and all of your particular engine specs that the program is capable of inputting. Remember, paper, ink, electricity and postage ain't cheap. What you will receive is well worth what I am asking. I will do a print out and post a picture of how many pages it includes shortly. Pleas PM me if you are interested. Thanks.
Here is what you will get. From left to right. Engine specs, cylinder head flow data, calculated power and engine pressures, manifold pressure and volumetric efficiency, and horse power and torque curves. That's five pages total with a lot of information about your specific build.
Here are some of the inputs that I need from you.
All the general stuff. Bore, stroke, compression, camshaft type and specs, intake and carburetor type, headers or manifolds (I can even in put for HP manifolds and large or small tube headers open or muffled exhaust), valve sizes, cylinder head flow data (or whether the heads are ported if you don't have flow sheets). That's pretty much it. I also have inputs for nitrous, superchargers and turbochargers. A lot of people scoff at the program, but I like it and think it is very accurate. The more information you put into it, the more accurate information comes out.
PM returned sir. Roy brought up a good point. Some of you might want to make comparisons between different engine components on an engine, or maybe do more than one engine. I can do that and will offer a discounted rate instead of 9.95 each. I will do two combinations for 12.95 and three different combinations, for example, for 15.95. Just let me know. Thanks.
BUMP! I now have the ability to send these as a PDF file in an email so I can send you something very quickly.
YOU THE MAN! Just received my build dyno. Tons of useful info besides HP and TQ. Got head flo, manifold pressure, efficiency % and more. Even got priceless help on improving my build. Best $ I've spent on my car.
Thank yall so much for taking advantage of this. Every little bit helps and Kitty and I really appreciate it.
Very good and cool info. The #s appear to be VERY VERY accurate. My #s came up almost exactly where the engine builder I worked with on my complete 416 build told me I would be.
Hmm. Ig I won't be able to do this till I build my engine as the only thing I know about this engine is its a 318 with a 340 Torker single plane intake, eddy 650 and headers. Don't know a thing more about it. I'm guessing stock but Idk.
But I will DEFINITELY be getting ahold of you once the time comes!!
Does your program include results for forced induction numbers, such as HP and TQ figures for 10, 15, 20 or even 30 pounds of boost, and if there is an alky chemical injector into the charge, is there any way to account for that?
Thanks for any info...
