73 duster restro mod
david98513
lacey, wa
hello all..
gonna be starting a thread about my 73 duster project..will be a complete restro mod car is a 73 duster, original 6 cylinder w/7.25 rearend..purchased the car when I was deployed to Afghanistan..car was purchased out of Eugene, Or..the original 225 is completely wore out and a a fresh 375 hp 360 will be installed with a 727 trans..body is extremely solid, only rust being a couple pin holes in trunk and some spots on roof from the vinyl roof..interior is factory green 60/40 front and benchback seat..auto on column and drum brakes all the way around..
modifications I will be doing and covering in this thread will be:
removing side marker lights, removing fender mounted turn signals, patch trunk and roof spots, removing the 225 and installing the 360, installing front disc brakes donated from a 78 cordoba, installing 8.25 rearend, installing rear disc brakes donated from a 95 jeep grand Cherokee, installing flaming river steering column, installing auto shifter on floor, removing and installing new interior with black leather power bucket seats donated from 96 Cherokee, making and installing new black leather wrapped interior panels, making custom leather wrapped center console, removing pull handle e brake from dash and installing e brake handle on floor, installing aftermarket power windows, making custom wood grain to match body color on instrument cluster, will relocate all engine electrical componets to trunk, installing hotchkis 1" lowering springs for back of car, new v-8 torsion bars, front and rear swaybars, and will be painting exterior of car gunmetal grey, will be powder coating all suspension and motor brackets, chrome will be painted body color.
this will be a very detailed thread will lots of pics and videos to go with restoration..and this car will be sold when completed..
Welcome aboard David!! It sounds like you've got a solid plan for a great car -- keep us posted on your progress and don't be shy with the pictures. :-D Hit me up if I can help you out with any of that.
:newb:
pics of car before I start
still trying to figure out how to upload photos..the motor in pic is 360 as it came out of 78 cordoba..the seats are from a 96 grand Cherokee, before and after they were cleaned.
more pics..
yes, the duster is very solid..just a couple small rust spots to deal with..im currently still gathering parts and hoping to get started on it soon..since the roof has issues from the vinyl roof that was on it, I decided im gonna shave the drip rails and graft a roof section from a newer bmw, this will add a power moon/sunroof..this will also add the interior dome light and make the interior a little more modern looking..im going for a old school look on body with minor changes and the interior look of a newer car..
more pics
Licence plate 'URF' thats funny, back to the urf it was headed! Good save.
still gathering parts..just got new air compressor, powder coat gun and 8.25 pig from newer jeep with 3:73 gears..
360 rebuild with stock crank, rods and windage tray. Factory iron 360 heads from a 1979 motor opened to 2.02" intake valves with a competition valve job. Bowls lightly blended and runners lightly cleaned up. TRW flat top cast pistons rated at 10. to 1 compression. Comp Cams Magnum hydralic 280 cam. This cam has a .480" lift and 280 degrees advertised duration. Intake is an Edelbrock Torker II. Topped with a edelbrock carb
401 h.p. @ 5,400 rpm
420 lbs. of torque @ 4,700 rpm
It looks like JF1 paint on the car. Would need to verify that on the Fender Tag...If it is, you have a rare 1-year only color.... My research and talking with multiple people on and off the net points to only around 300 Dusters coming in that color for the year. I'm gathering up parts to start restoring a 73 Duster 340 JF1 car with the V21 performance hood treatment.
yes, it is a jf1 color car..was only a one year color..i thought about putting back to jf1, if it was a original 340 car, I would. since its a 6 cylinder car and no real special options, im gonna upgrade to a more modern look.
many hours scrapping is a understatement:violent1: It it well worth it in the end. Looks like a solid starter
well, I finally had a chance to get started on the duster..got the interior stripped down to the floor..the person I purchased car from told me someone added a floor shifter, cool I thought..until I got the carpet out, it must have been one helluva shifter..the hole is huge..rest of floor pan is good, gonna patch the tunnel and get the floor in primer..the rust spot beside the tunnel is from where someone put the cowl drain behind the tunnel..why? I do not know..
finally had some free time to work on the duster today..got the trans tunnel and small rust area trimmed and ready for the patch work..also decided im going to update the door handles with something from a new car, haven't decided what style yet, ill probably decide when I see them in a junkyard. also going to update and put modern mirrors on it.
