Wanted- K frame Schematics
1967formulaS
Adelaide, South Australia
Hi guys, I am looking for a tech drawing or Schematics for a 67 Barracuda Big block K frame.(needs to include measurements).
In particular the centre measurement from one LCA tube to the Other.
I have the 67 Service workshop manual but nothing in there with measurements.
My K Frame has cracked the weld around the tube where the lower control arm pin goes through.( Its real messy). Anyway, before I go and replace the tube and weld it up I would like to make sure the measurements are within specification. any help would be appreciated.
By the way, that is information I do not have. I haven't needed it. I could come up with the measurements, but it would take several days, up to a week or two.
Just hire Jim to whoop you one up. Problem solved.
24 1/2" center to center on the LCA pivots on a 67 273 frame I just measured.
I would think all 67-76 A-bodies are the same.
Yes, they would be. A height would also be necessary, but if the k-member had one in the proper location the other side should be the same.
Thanks for the info Guys,
I did find some schematics on the Jim Childs Hemi Dart and Barracuda Authentication guide, The writing is very small so I will try and increase the size and post a link on here for everyone. :burnout:
That is the most informative book I know of on those cars but could have been done better.
I couldn't make out that print or a lot of the pictures. 1800s news paper quality printing was so bad I couldn't make it out with a magnifying glass. Hope you can do better than my 50 year old welders eyes.
Do keep us posted, always wanted to know what was on that page.
