[SOLD] NEW Slant-Six Export 2bbl Carburetor
Vancouver BC
This is not "remanufactured" junk (you can buy for about $200).
This is also not "new" Chinese knockoff garbage (you can buy for about $250).
This is a perfect new-in-original-box American-made Carter BBD 4301S 2-barrel carburetor, part number 2843 102. Original equipment on export-spec 1967-'70 cars with the 160hp Power-Pack 225 engine. Bolts directly onto a factory, [ame=http://u225.torque.net/cars/tech/SL6/Parallel_2bbl.pdf]fabricated[/ame], or Mopar Performance Slant-6 2bbl intake manifold; has standard Chrysler 2bbl throttle/kickdown linkage hookups, accepts any standard 2bbl air cleaner. Nipples for distributor vacuum advance and for PCV. Integral choke for use with heat tube and exhaust manifold so equipped, or use a low-cost choke tube kit and run it with any exhaust manifold or headers, or dispense with the heat tube completely and swap to an electric choke with a readily-available kit.
Since mentioning this carb in a previous thread, I've had some PMs come in; those board members are first in line in the order their PMs came in. (Somewhere in my mountain of Stuff is a 2bbl air cleaner assembly, but it's hiding or hibernating; I will list it separately if and when it shows itself).
Price: $279. Postal shipping from Seattle WA (or Vancouver BC for a Canadian buyer).
