[SOLD] New Pair of Weber Carburetors
Vancouver BC
Here's a pair of new (not mounted, gasoline never in them) Weber 36 DCD-14/F 23R progressive 2bbl carbs, ideal for a Slant-6 hop-up. I bought them for my '73 Dart, but sold the car before getting around to the project.
Mount these on an easily-available, easily-modified Offy #5041 twin-1bbl intake, attach easily-available throttle linkages and air cleaners (I don't have these parts, this ad is for the carbs only), and off you go. That setup looks like this:
These carbs are highly and easily tunable. All jets and tubes are selectively changeable to get the mixture dialled in exactly right for your engine, and clear tuning literature is easily available. They have a manual cold-start assist device that operates with a simple pull cable like a choke, but doesn't have choke plates.
These are genuine Weber units, not Chinese knockoffs, and they are current-production carburetors, just a couple of years old, not old stock -- so no problem with modern fuel formulations. They have built-in throttle return springs, compound venturis, and ported vacuum available for distributor advance.
Find this exact carburetor on the web for between $440 and $600 each. Buy mine for $779 for the pair.
Shipping from Seattle, WA.
Easy work; the carb mount pads on the Offy intake are already large, rectangular, and machined flat. On each pad, drill and tap four holes for the studs, and enlarge the plenum hole from round (1bbl) to oblong (2bbl).
