Tag Stamp Decode
Aspen77
Member
TN
Can someone help with the codes please. Thank You.
483
M43 N37 R11 L1 13
H51 K9B M21 M31 M33 M38
PB9 U1 B41 G11 G52
PB9 D2B3 000 B04 262635
E26 D31 NH29 D7B 225398
Probably gonna be tuff as the newer cars are. Use the search feature on this site to find other members with Aspens. One of them may have decoded theirs.
I think I have it correct...
NH29:
N = Aspen
H = High Trim Grade
29 = 2 Door Sports Hardtop
D7B
D – 225 2-bbl /6
7 - 1977
B - Dodge Main, Hamtramck
225328 - Sequence number
E26 – 225 2-bbl /6 - 110hp@3600 & 180Torque@2000
D31 – Std A904 Auto Trans
PB9 – Starlight Blue Sunfire
D2B3 – D2 Vinyl Split Back Bench Seat, B3 Blue Color
000 - Full Door Panels
B04 - Build Date: November 04 1976
262635 - Vehicle Order number
PB9 - Dark Blue Top Color
U1 – USA Specifications
B41 - Power Front Disc Brakes 10x2.5” rear Drum
G11 - Tint All Windows
G52 - Left - Outside Remote Mirror - Chrome
H51 - Air Conditioning
K9B – ? K9 Tape Stripe, B=Blue
M21 - Roof drip rail moldings
M31 - Belt Moldings
M33 - Body Side Moldings
M38 - Trunk Finish Panel Moldings
M43 - Grille Trim Moldings
N37 - Catalytic Exhaust System
R11 - AM Radio
L1 - End, Hamtramck Line 1
13 - Body Frame Jig
483 - 483 Car Built that Day
These newer 74-up cars are tough, as are the 66 an earlier! A lot of digging. At least I am noting it as I go.
Probably K3B instead of K9B
Yes as Rocky mentioned, it's a blue stripe, likely up and over style
The reason I ask is because some things do not add up. I do not have a clock in the dash. I have been told it is a special edition when in fact I think it is a base coupe. Thanks for the feed back.
If the tag is correct in engine that is cool but like I said some options are missing I do believe. Just trying to get her right like she should be once again.
Also inside driver door sticker reads car was manufactured October 1976 but title reads 1977 of year.
Yes your car was built Oct of 76 and its a 1977 model. When a vehicle was made after August of any year, its considered the next model year
New model year begins August 1, Your fender tag shows 11/4/76 as the "scheduled production date." This date is not necessarily the actual production date, which may be earlier or later by weeks possibly.
I have been trying to find all the chrome trim for this restore and it seems almost impossible. Just like trying to find a nice pair of door panels for it. I am on other mopar sites but have not had much help with a parts list. I have listed. Thank You.
