[FOR SALE] Even more exhaust manifolds
Treblig
South Texas
From Corpus Christi, Texas. One original set of '69 318 manifolds. I removed these from my '69 Barracuda. $75 for the pair plus shipping. I also have other small block Hi-Perf manifolds for sale here:
http://www.forabodiesonly.com/mopar/showthread.php?t=286272
Gray manifolds are 340/360 mags check hot key for prices...some of these are already sold.
Treblig
What are the #'s on the 340/360 manifolds? Are they altered
Not quite sure what you mean by altered??? I only have one pair of 340/360 manifolds left and the 360 in this pic is sold although the 360 exhaust manifolds I sell are all the same casting number as seen in these pics. The 360 manifolds I sell are all identical. I machine them so that the exhaust hole is basically ported and smoothed out to approximately the same size as the 340 driver. I have sold out of 360 manifolds but am in the process of making more. The 340 manifolds are much harder to get but I can get them, prices may vary. I will sell the 360 "machined" manifolds separately for those folks who already have a 340 driver. But I only sell the 340 manifolds paired with a 360 "machined" mag. NO serial numbers are altered. If you use the hot key in my other post you'll get more info.
treblig
Forgot to mention that I can get these original '69 318 stock manifolds sand blasted and painted (high heat paint) for an extra $10.
$75 plus $10 = $85 plus shipping
Treblig
Treblig
BUMP for the stock 318 '69 Barracuda manifolds.
Treblig
Still for Sale original '69 318 manifolds.
I also sell 340 and 360 magnum manifolds. I sell them in sets only. I machine the 360 magnum to be very close to the same size as the 340 2 1/4" exhaust outlet. However I will sell the 360 mag manifold separately. The sets (340driver with 360 passenger) sell for $320 plus shipping. I have 360 mags in stock but I don't always have 340s in stock, you'll have to check with me.
I also have large hole Dakota driver manifolds!!!
Thanks,
Treblig
Do you have a set of 340 manifold available? Need for powersteering. Thanks.
I don't have any 340s at the moment. But I don't sell the 340 individually anyway. I sell the 340 driver paired with the 360 "machined" magnum to save members money.
Just go here and you can read about the manifolds I sell:
The price has changed a little so read the whole thread. I do currently have 360 "machined" magnum and machined large hole DAKOTA manifolds available. I'm waiting for a deposit on the last set of 340/360 mag manifolds. If the FABO member doesn't send a deposit then this last set can be yours if you send a deposit.
Treblig
SOLD!!! The original 318 driver's manifold has been sold. All I have left is the original 318 passenger manifold off my '69 318 Barracuda. $40 plus shipping!! This 318 passenger manifold can be seen in the first pic of this thread.
I also have many other 340, 360 Mag and Dakota driver manifolds. These are all large exit hole and can be seen here:
http://www.forabodiesonly.com/mopar/showthread.php?t=286272&highlight=340/360+manifolds
Thanks,
Treblig
BUMP ...BUMP.........I sold the original '69 Barracuda driver 318 manifold so now I just need to do is get rid of this original passenger 1969 318 exhaust manifold. Open to offers???
http://www.forabodiesonly.com/mopar/...=286272&page=3
Treblig
I also have many other 340, 360 Mag and Dakota driver manifolds. (EXAMPLES BELOW)These are all large exit hole and can be seen here:
Treblig
I also have many other 340, 360 Mag and Dakota driver manifolds as well as flared down pipes and flange adapters. (EXAMPLES BELOW)These are all large exit hole, sell at different prices and can be seen here:
Treblig
BUMP ...BUMP.........I sold the original '69 Barracuda driver 318 manifold and still have this one lonely original passenger 1969 318 exhaust manifold. Open to offers, don't be afraid???
Treblig
BUMP ...BUMP.........I sold the original '69 Barracuda driver 318 manifold (SECOND PIC) and still have this one lonely original passenger 1969 318 exhaust manifold. $30 (PLUS SHIPPING) for the stock 318 passenger manifold....Open to offers, don't be afraid???
XMAS IS RIGHT AROUND THE CORNER!!!!!!!!!
Treblig
Treblig
I also have the smaller 340 exhaust manifold, it has a 1 7/8" exhaust hole which is larger than the 1 5/8" stock 318 manifold. you can see it here:
http://www.forabodiesonly.com/mopar/showthread.php?t=299004
Treblig
http://www.forabodiesonly.com/mopar/...d.php?t=299004
Treblig
Treblig
http://www.forabodiesonly.com/mopar/showthread.php?t=286272&highlight=treblig
I also have the smaller 340 exhaust manifold, it has a 1 7/8" exhaust hole which is larger than the 1 5/8" stock 318 manifold. you can see it here:http://www.forabodiesonly.com/mopar/showthread.php?t=299004&highlight=treblig
Treblig
I also have many other 340, 360 Mag and Dakota driver manifolds as well as flared down pipes and flange adapters. (EXAMPLES IN THE LINK BELOW)These are all large exit hole, sell at different prices and can be seen here:
HAPPY NEW YEAR!!!!!!!!!!!!!!!!!
Treblig
