Old School 'C/FX' 273
69 Cuda 440
Legandary Member
Legendary Member
Wilton, Connecticut
June 1965
Dick Maxwell {Head of Chrysler Performance} talked Dave Koffel into campaigning
in the 'C/FX' Class for the second-half of 1965.
The 1965 Plymouth A-990 ~ 4-Speed ~ 426 Race Hemi {SS/A} was replaced with a
273 Engine.
The 1965 A-990 with the 273 4-Speed would weigh in at 3570 lbs.
3570 lbs. ~ 273 = 13.07 Weight/Cubic Inches
* C/FX Class = 13.00 and up
In early 1965, the C/FX National Record was a 'soft' 13.92 @ 101.46 MPH.
In NHRA Racing, a C/FX Class Winner would compete in Stock Eliminator
against Stock Class winners.
At the time in 1965, the hottest car in C/FX was a 1965 Ford Galaxie 500 '289'
driven by Bill Hoefer {California}, who was backed by the Ford Racing Division
on the West Coast.
I see a flaw in your math. Is it weight to cubic inch or weight to horsepower? Weight to cube is: 3570 lbs. ~ 273 = 13.07 Wt/Hp
T-M-M,
C/FX was ........... Weight-to-Cubic Inches
My error on 13.07 Wt/Hp ......... :violent1:
It should be '13.07' Weight-to-Cubic Inches
T-M-M,
No harm/ no foul. I was thinking they might have used the 275 horse D Dart engine. LOL
TMM
Original Engine Specs
Engine............................ 273
Crankshaft...................... Standard 273 Forged Unit {Casting #2128869}
Main Bearings................. 'Federal-Mogul' Fully-Grooved {Upper} and Standard {Lower}
Connecting Rods............. Standard 273 'Shot-Peened'
Connecting Rod Bearings.. 'Federal-Mogul'
Pistons........................... JE Lightweight ~ 10.5 - 1 {+.140" Dome}
Rings............................. Dykes {Top Compression} ~ Low-Tension Oil Ring
Oil Pan .......................... 9 3/4" Depth w/Baffle {8 Quart}
Oil Pump........................ Mopar High-Volume
Oil Pump Pick-Up............ 426 Max-Wedge 180* Swivel
Deck Block .................... {- 011"}
Piston Dome Height........ {+.129" above block}
Cylinder Heads............... Standard 273
Intake Valve.................. 1.94" {354 Hemi}
Exhaust Valve................ 1.56" {354 Hemi, cut down}
Valve Seats................... 5-Angle {70*, 60*, 50*, 45*, 40*}
Valve Seat Top-Dress...... 0*
Seat Angle Depth........... 1"
Combustion Chamber..... 51.3 CC
Net Compression........... 12.5 - 1
* Note: Porting is not allowed in C/FX Class. Only 'approach angle' valve-seat/bowl-blending at 1" depth maximum.
* Note; Cylinder Block notched {eye-browed} to allow for Valve clearance.
* Note; Valve-to-Piston clearance set at .060".
* Note; Internal components balanced.
Camshaft.................... Racer Brown #ST-12 'Mechanical'
Lift............................ .480"
Duration..................... 284*
Overlap...................... 60*
Centerline................... 108*
Valve Springs.............. Racer Brown
Outer......................... #VR-18x
Inner......................... #VR-56
Installed Spring Height. 1.68" to 1.70"
Load Rate................. #130 lbs. Valve-Closed ~ #313 lbs. Valve-Open
Lifters........................ Chrysler Hemi Tappets {-.0005" Undersize}
Intake Manifold............ Edelbrock #D-66 {In-Line Dual-Plane Dual Quad}
Modifications............... Port Runner/Gasket Matched ~ Throttle Bore Openings Chamfered 1/4" Depth, Smoothed and Polished
Carburetors................ {2} Carter #3853S ~ 1965 273 Manual ~ {460 CFM} ~ 1 7/16" Primary and 1 9/16" Secondary
Mopar Tech Adjusted...
Front Carburetor......... Remove 'Step-up Springs' from Primary Metering Rod ~ Install {Primary} #16-216 Metering Rods
Rear Carbretor............ Install {Secondary} #120-176 {.0635" Jets} ~ Install lighter 'Velocity Valve Springs'
Pretty impressive specs. Too bad hey couldn't port the heads but the 5 angle valve seats with larger valves had to help. 12.5/1 doesn't hurt either. Fun! tmm
T-M-M,
The '1st' 273 'C/FX' Engine was putting out between 315 and 320 Horsepower.
Included were;
* Stahl Custom Designed Headers
* Primary Tubes .......... 1 3/4" Diameter
* Tube Length ............. 30"
* Extension ................. 3 1/2" Diameter x 8" Length
* Collector .................. 12" Length {O.D. Tapered down from 3 1/2" to 3"}
* Outlet Opening ......... 2 7/8" Diameter O.D.
* Header Flange Thickness = 1/4" {to prevent scavenging}
Note: The primary tubes 4-Pipe 'clover-leaf' connection in the 'extension' had the center section
closed off and brazed with sheet-metal. This was to prevent back-flow pressure from effecting
the exhaust flow between the tubes.
I wouldn't mind finding a 64 or 65 B Body with a 273 myself. I am a big fan of the early 60's B's.
July 23, 1965
York US 30 Dragstrip ~ York, Pennsylvania
NED 1 Points Meet
Just 1-Week after setting the C/FX National Record at Muncie Dragstrip, Dave Koffel
was back at it again.
New Record ........ 13.36 @ 104.45 MPH
Hot Rod Magazine {February 1966}
Photographs and Interview from November 1965 at Detroit Dragway
Wicked cool. I wonder what he shifted at? Thanks 69
7000 RPM's
Dave Koffel was running 4.56 Gears in the #3570 lb. 1965 Plymouth Belvedere A-990.
The 4-Speed was a 'Slick-Shift' A-833 Transmission.
According to Dave, they scorched the Rod-Journals of the 'stock' Forged Crankshaft 'black'
a few times with several 7000+ RPM shifts.
Then they went to a 'special' Tuftrided 318-3 Crankshaft and 'custom' Howard's Aluminum Rods
and were soon pulling 7500 RPM shifts.
that car was the inspiration for my '65 Belvedere build!
Video of the car!
[ame="https://www.youtube.com/watch?v=2HxX07hJfEA"]https://www.youtube.com/watch?v=2HxX07hJfEA[/ame]
Video of the car!
[ame="https://www.youtube.com/watch?v=2HxX07hJfEA"]https://www.youtube.com/watch?v=2HxX07hJfEA[/ame][/QUOTE
That, rocks....
Sounds great! We need information on the build.....inquiring minds want to know! lol
Dave Koffel 'C/FX'
According to Dave Koffel, on paper the modified 273 in the 1965 Belvedere was going to run
under the 13.92 @ 101.46 MPH National Record.
After 2-Weeks of testing at Dragway 42 in West Salem, Ohio in early July 1965, the 'C/FX' car
was running in the 13.50's @ 103 MPH.
But, they were cooking the Crankshaft {black rod journals}.
They switched the 'stock' Forged 273 Crankshaft with a 318-3 'Tuftrided' Crankshaft from a 318 Truck.
On July 16th, at Muncie Dragstrip in Indiana at the Division 3 Gold Cup Meet, they smoked the record
with a 13.45 @ 103.21 MPH {Below}
[URL="https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcTZErduCTGx9uNQkunbQti7JGgXPt9lahelznMpl_uKY5rlsoSb"][URL="https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcTZErduCTGx9uNQkunbQti7JGgXPt9lahelznMpl_uKY5rlsoSb"][URL="https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcTZErduCTGx9uNQkunbQti7JGgXPt9lahelznMpl_uKY5rlsoSb"][URL="https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcTZErduCTGx9uNQkunbQti7JGgXPt9lahelznMpl_uKY5rlsoSb"][URL="https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcTZErduCTGx9uNQkunbQti7JGgXPt9lahelznMpl_uKY5rlsoSb"][/URL][/URL][/URL][/URL][/URL]
After that July 16th meet, they pulled the 273 Engine and brought it to 'D & D Engine Rebuilders' in
New Brighton, Pennsylvania for a quick refreshing.
They swapped out the 'stock' Forged Connecting Rods for a set of 'custom' Howard's Aluminum Rods.
1-Week later
On July 23rd at York US 30 Dragstrip in York, Pennsylvania at the NED 1 Points Meet, Dave lowered
the C/FX National Record to 13.36 @ 104.45 MPH.
sorry to say that the original 273 from my car was beat too hard to bring back. So in it's place is a thinly disguised 360- original replacement motor from '74 (just put together now), 1968 340 intake, Edelbrock 650 thunder series, Hughes Whiplash 340/360 cam, billet valve train, TTi headers, Mopar ignition
..and of course 273 valve covers and breather.
That sounds like lots of fun! I thought it had a deeper growl than a 273 has. lol tmm
More on Dave Koffel
Following lowering his own C/FX National Record on July 23, 1965 at York US 30 Dragstrip.
Dave was back home in Massilon, Ohio.
He pulled out the 273 Small Block. He then re-installed his 426 Race Hemi Engine, to get
prepared for the Big Event on August 7, 1965 ~ the Super Stock Magazine Nationals at
Dave was classed in SS/A {3400 lbs. Weight Class}.
Dave set the 'Low' Elapsed Time at 11.09, and won Class.
But Dave was knocked off by Tom 'Smoker' Smith in Top Stock Eliminator.
Photo Below; At the Super Stock Magazine Nationals
[URL="http://www.thevintageracer.com/65ssntl/1965-005.jpg"][URL="http://www.thevintageracer.com/65ssntl/1965-005.jpg"][URL="http://www.thevintageracer.com/65ssntl/1965-005.jpg"][/URL][/URL]
[/URL]
