Found a wire
Dart swinger 73
Ft Lauderdale
Going through my wires I found a long blake wire with a plastic 90* boot. Can't find a place in the engine compartment for it. It looks like it would except a single pin. The wire is about 3 ft. long. Having a automatic tranny I have 3 pin connector there. Any idea would help a lot. :coffee2:
I think the temp sender wire is purple. Diagrams call that violet.
The one that goes on the brake warning switch at proportion valve might be black.
Once again I'm compelled to remind
SERVICE MANUAL
For 73, look up the connector diagrams in the rear of section 8 Engine bay connectors are "CE" and "instrument" panel connectors are "CI"
These diagrams start about page 8-164
If you can't find it post back. You MUST try first.
I'm gonna start charging for this, and it ain't gonna be cheap....................
