[FOR SALE] slant 6 crank pulley
woody30
woody30
walton ny
Here is a slant 6 crank pulley from a 68 Barracuda . $10 plus shipping from Walton NY 13856. I have an oil pan, valve cove, rocker arms etc from the same motor. PM me if you need any of those parts.
Bump. Have other slant parts. CHEAP. Valve cover, rocker arm assembly, oil pan. Will sell all for $50 plus shipping.
Just to help you out that is the pulley needed to add power steering to a slant six it bolts on the front of the damper.
Brian
makes a good trigger wheel too as it bolts to the hub. just machine 36-1 notches in it.
