Parts still available from your mopar dealer
AdamR
Big Member
Bethel, CT
M-PARTS GLOSSARY
Thank you for supporting your local Mopar dealership. The more of these parts that continue to be purchased greatly increase the chances of many of these parts as well as the cars they fit to be around for many more years to come.
All part numbers have been looked up [one by one] in Chrysler parts books and checked against the current Chrysler price list for price & availability by certified Mopar Parts Specialists.
However this list does not guarantee availability as parts are cancelled NS1 (no longer serviced, not available). If a number has gone NS1, request the parts person to run the part number on the Chrysler locator. The locator checks for parts in other dealer's inventory throughout the US.
There is no liability expressed or implied, due to incorrect or invalid part numbers or parts being unavailable.
Belts and hoses are not listed individually since they are readily available through any Mopar Parts Dealer, consult the MOPAR BELTS AND HOSE CATALOG FOR CARS AND TRUCKS.
GLOSSARY OF TERMS
***'y: assembly A ENGINE: 273, 318, 340
AT: automatic transmission B ENGINE: 383, 400
cyl: cylinder RB ENGINE: 440
dia: diameter
exc: except
ft: front a/m: all models
h/l: headlight w/: with
lt: left w/s: weatherstrip
mldg: molding w/o: wheel opening
MT: manual transmission
pkge: package
pwr: power
rr: rear
rt: right
ss: superceeds to, this is not the original part, but the part is exactly
the same, having a new part number assigned for various reasons or
this part is a correct substitute and works just like the original.
A BODY: Dart, Dart Sport, Duster, Demon, Valiant, Signet, Swinger,
64-69 Barracuda
B BODY: Coronet, Charger, Roadrunner, Satellite, GTX, Belvedere
E BODY: 1970-74 Barracuda, Cuda, Challenger
C BODY: Newport, Fury, Polara, Monaco, New Yorker
F BODY: Aspen, Volare H N
Y BODY: Imperial
T BODY: 79-81 Newport, St Regis, NYR
V: Valiant, Duster L: Dart, Dart Sport, Demon, Swinger
B: Barracuda-do not confuse w/ "B body" J: Challenger
R: Belvedere, Satellite, GTX, RoadRunner W: Coronet
X: Charger P: Full size Plymouth-C body
D: Full size Dodge-C Body
C: Chrysler Newport, New Yorker, 300, Town & Country
Y: Imperial
H or N Aspen Volare'
COPYRIGHT 2003, M-PARTS PUBLISHING ALL RIGHTS RESERVED.
THIS PUBLICATION MAY BE REPRODUCED IN WHOLE OR IN PART BY COPIER
OR ANY OTHER MEANS WITHOUT WRITTEN PERMISSION FROM THE PUBLISHER.
Prices shown are list price
118112 : self locking shifter plate bolts-3 req, hex head beveled side bolts all manual transmissions,
ss to 6029799 $2.85 ea
118614 : Air cleaner wing nut $0.70
120393 : washer-used w/ 6026776 clip-retains kickdown rod to throttle stud
ss to J0120393 $2.35
120394 : washer-manual trans gearshift rod swivel to shifter ss to:J4001104 $2.95
0219462: nut for throttle bracket clamp ss to: J0120375 $2.45 ea
0220800: bolt-viscous fan bolts 4 req $2.25ea
1122532: Engine to trans locating dowel 2 req 0.500 diam $1.85 ea
1302807: gasket-backup light switch manual trans-all models $1.20
1315466: 5/8 heater hose 50 foot roll. ss to 4741932AB $57.50
1316815: O-ring transmission oil fill tube all automatics ss to 6030608 $2.25
ss to:6030608 msq8 $2.25 ea
1319554: washer outer rear shock bushing a/m $0.20
1319555: washer inner rear shock bushing a/m $0.95
1400269: bushing-rear spring shackle-all models exc A body
and non HD Y msq5 $3.75ea
1613416: cap; front wheel bearing, all models exc 9' brakes up to 1972 $7.25
1618732: cam bolt washer-A engine $3.75
1618670: camshaft thrust plate A engine ss to: 4315764 $6.50
1622535: bolt- square head battery terminal a/m ss to 6033795 $1.70
1622536: nut for battery terminal bolt ss to:60335223 $1.75
1670694: filter-gas tank sending unit pickup,5/16" a/m $6.25
1686198: radiator pet Johnson, a/m $4.20
1730095: retaining ring-fuel float ***'y a/m $6.60
1821414: Bolt-harmonic balancer-A & hemi engine ss to bolt washer ***'y 6036207AA $5.50
1826286: Air cleaner stud, all 4bbl carbs $11.75
1828352: battery holddown strap 63-69A, 64-69 B, 68-73Y $16.95
1838508: spring clip-distributor cap hold down all Chrysler distributors msq10 $1.75 ea
1841499: Spark plug wire separator 4 wire free standing $2.35
1855561: washer-harmonic balancer bolt-all V8s ss to bolt washer ***'y 6036207AA $5.50
1859788: dip stick tube 64-69 A engine $12.00
1940725: bushing-rear shackle-all A Bodies $4.95
1943547: bumper, glovebox door hinge-E body ss to: 5216050 $1.70
1945473: B-RB engine aluminum rear main seal retainer $58.70
1947612: A engine distributor clamp ss to 4343950 $4.20 ea
1947708: spark plug tube seal 6 cylinder engine $4.60
1948757: seal fuel tank float ***'y all models ss to 3404451 $1.25
1949424: bolt, flexplate to crankshaft, all models ss to 6035462 $1.70 ea
2070933: 8-3/4 axle foam gasket-backing plate to axle msq5 $2.35ea
2071173: torsion bar rubber boot all models exc imperial & c body $17.20ea
2071204: bushing-upper control arm 67-72 B body, 70-74 E body $16.75ea
2073687: spring-retains throwout bearing to fork-uses 2 4.10ea
2074089: Battery hold down stud short/inner side msq5 $5.00ea
2084467: 5/16" fuel filter, fits all Mopars; $7.60
2121223: exhaust manifold washer A-engine, slant 6 ss to 53010091 msq4 $2.00ea
2124499: 4-sp main drive pinion retainer gasket $2.60
2124715: vent manual trans and rear axle all models $5.25
2201467: retaining clip, emergency brake rear cables a/m $2.10ea
2204728: Converter door drain, 727 all models $1.45
2204768: flexplate: 11.75" converter, 727 Automatic $86.95
2206925: front shock bushing retainer, this is the washer $1.95
2216552: grommet-speedo cable all models ss to 3593446 $2.75
2217508: clip-window belt w/s outer/inner all V,L, outer only all BJRWX msq10 $0.25ea
2258862: ground strap fuel tank sending unit a/m $9.10
2260787: wheel cyl push rod, 2/wheel all drum brakes $3.25
2260788: brake shoe guide plate, 11" brakes ss to J3201032 $3.10
2265656: upper bearing steering column 66-71 all models $20.10
2265938: clutch torque shaft bearing, 4 required all models msq10 $2.25ea
2265942: clutch torque shaft bearing seal 2 req all models msq4 $6.60
2266783: clutch rod firewall boot. all models NS1
2269127: upper ball joint seal all models exc A & Y body $9.50
2269214: seal-lower balljoint All V,L,B,J,R,W,X Models $8.20
2269250: seal-torsion bar end all C bodies $2.85 NS1
2269709: bushing C body sway bar $12.00
2276804: rubber bumper-leveling-fender extension to hood,
similar to 3788362 msq5 $2.20ea
2292995: Round dome light lens all models $16.25
2400163: seal output shaft Manual trans A833 2-1/2" yoke $22.85
2400885: flexplate: 10.75" converter, 727 Automatic ss to: 4058429 $40.70
2401768: parking brake equalizer cable, all models 1970-71, exc 71 B/E body
ss to: 4294951 $4.60
2401910: torque shaft bearing retainer holds bearing in place(clutch part)
all models msq5 $8.20ea
2405049: clip, fender seal or cover on inner fender msq2 $0.95ea
2404216: outer axle seal 8-3/4 axle $10.35
2402903: nipple-A Engine bypass hose screws into manifold, ss to 53020185 $5.10
2405077: throwout bearing assy 10-1/2" clutch [excellent part!!!!] $77.10
2405085: U shaped metal retaining spring washer for clutch linkage msq10 $3.00ea
2405086: plastic anti friction clutch linkage washer msq5 $2.10ea
2408143: gasket for neutral safety/backup light switch 2932280 msq5 $2.20ea
2409826: rt hand thread, lug nuts-steel wheels msq5 $2.45ea
2424864: plug-floor pan 1-3/4" hole $3.00
2444442: starter relay 70-74 A-B-E body ss to 4638260 $16.85
2461765: clutch torque shaft pivot engine side $21.25
2461766: clutch torque shaft pivot frame side $46.70
2463512: small block oil filter adaptor cork seal for bolt msq5 $2.45ea
2466302: oil level indicator 904 & 727 trans exc Hemi, ss to 4202951 $9.45
2466954: tail shaft to main housing gasket torqueflite trans msq5 $2.25ea
2468849: Oil pickup/screen, A engine $40.20
2480957: plug-floor pan 1" hole ss to 4780194 msq6 $2.50ea
2483571: plug-floor pan 2-1/2" hole $4.45ea
2486468: door hinge bushings msq5 $2.60ea
2495531: ignition coil all engines/models $42.10
2497500: cap for windshield washer reservoir a/m $2.45
2497502: windshield washer reservoir 1968-69 A body 2 speed wipers $32.20
2530538: cover-steering pot coupler-rubber seal to coupling $9.25
ss to coupler rebuild package 4443436AC
2533822: parking brake lever strut spring, inside brake drum 11" brakes
ss to 4773942 $2.00
2534111: filter-gas tank sending unit pickup, 3/8-hemi models NS1
2534240: A engine clutch release rod $47.10 Fits 70B/E body
2534814: batttery holddown stud outer long msq5 A body63-76 B body 70-74 $6.10ea
2535027: lower control arm rebound bumper A Body $18.45 4
2536121: engine mount insulator 71 B body w/ A & B/RB engine; 70-72 E body
w/ A engine, 66-72 B body w/ A/B/RB engine $34.70
2538785: internal baffle A 833 manual transmission. $2.75 NS1
2538926 thru 2538945: speedometer pinions all models 1966-75
last two digits denote # of teeth, most ss to jeep #'s $14.60ea
2579443: "FORMULA S" nameplate $29.85ea
2579804: nameplate "383 4 BARREL" fender $35.90
2583377: retainer-ft door lock All V,L models, 68-70 R,W,X,P,D,C,Y models msq5 $2.70ea
2583860: outside keylock gasket all models exc B,J ss to55074799 msq2 $1.95ea
2643705: clutch release fork return spring all models $6.20
2643707: automatic trans rubber brake pedal pad 68-70 B-body ss to: 3575101 $7.10
2770662: positive battery cable 68-73 A body A engine $123.00
2781932: trans yoke large U joint ss to 4384437 $159.00
2784714: rubber bumper hood leveling-rear corner-all models; decklid E body $4.10ea
2785434: shroud-radiator fan-26 inch 66-69 B Body $89.85
2801398: tail shaft bearing inspection cover gasket $1.60
2801692: input shaft oil seal manual trans msq2 $5.35 2
2801724: A-833 4-sp & 727 AT tailshaft bushing $9.10
2801893: gasket, bearing retainer A833 4-sp $1.70ea
2806779: Insulator 67-76 A engine A body $32.10
2806982: short exhaust manifold nut for B-RB engines $9.20
2808579: shaft pkge lwr control arm B/E Body, includes bushing $45.00
2809011: windshield washer reservoir 67-76 A body variable speed $37.00
2809013: windshield washer pump electric 70-74 E body & 70+ B-body $39.75
2811263: windshield weather strip 68-70 B-Body 2 dr exc convert. $156.00
2811825: rubber plug-clutch rod hole in cowl-all models $0.35ea
2822261: windshield wiper limit resistor, 2 speed All models $14.20
2822583: lens, glove box light, round, 66-76 most models $4.85
2823845: wheel dome retainer for 3580466 road wheel dome $9.00ea
2823848: rt hand thread chrome wheel lugs 4-1/2 bolt pattern msq5 $4.25ea
2823849: lt hand thread chrome wheel lugs 4-1/2 bolt pattern msq5 $4.25ea
2835896: tie rod end seal msq5 $6.35ea
2841886: "CHARGER" roof nameplate 1968-70 $32.10
2843770: fuel pump gasket, all models $2.10
2843892: bellhousing inspection cover A engine 4-speed $45.25
2852323: trans yoke 727/833 trans small U joint $124.00
2860332: plug-rubber-antenna hole in cowl-all models $2.00
2863735: engine mount isolator 70-72 E body w/ B-RB engine ss to 2536121 $34.70
2875604: spark plug wire separator 4 wire A engine $2.10ea
2879600: sill plate 70-74 E body $59.25
2880434: gas tank 68-70 Charger only $340.00
2880481: gas tank filler tube grommet 1966-69 B Body & 67-74 A body
ss to: 3404182 $12.25
2880829: cancelling cam, turn signal switch $121.00
2883402: shifter knob, AT column shift, all models ss to 4147350 $7.60
2884730: cable, heater temp control 70-74 B,J,R,W $25.00
2889565: ignition lamp time delay relay msq2 $11.85ea
2889783: speedo cable all Mopar A/B/E 68 thru approx 75. not for cruise control
ss to: 4897646AA
2889785: cable trans to cruise control servo 1967-1981 models
2889803: windshield washer reservoir 1967-70 B body $30.95
2889935: antenna base gasket all models $2.60
2892399: clamp-speedo drive pinion adaptor housing to trans all models 64-89 $3.70
2892263: pivot-clutch fork B-RB-Hemi engine B,J,R,W models $26.05
2895870: windshield weatherstrip 70-72 V L fastback only $132.00
2899246: dipstick B-RB motor 1968-9 $10.00
2899339: throttle cable 68-71 383-440 engine, B body $49.00
2899530: crankshaft oil slinger, all engines $6.75
2899808: oil pickup/screen, B-RB engine 5 quart pan $38.45
2901812: nameplate-"R/T" 69 W,X 1/4 panel $36.85
2925322: battery tray 70-73 E & 70-72 B Body $31.70
2925492: spring-steering column coupling ss to package 4443436AC $6.10
2926275: stop light switch, heavy duty, C & Y body $30.35
2932230: vent window weatherstrip channel 68-74 A & 68-70 B-Body $37.35
2935375: hood release pop up spring, 70-72 all models except 70 W V L models $3.45
2936388: 1/2 inch heater hose 50 foot roll $43.50
2946079: grommet, valve cover breather msq4 $3.95ea
2947798: cruise control brake switch A B E C Body $33.60
2947801: turn signal switch 66-69 A body $53.35
2947953: turn signal lever E-Body $50.00
2947963: turn signal lever A & B Body $47.20
2949228: wedge-spring loaded-hood to fender alignment 70-74 BJ, 71-74 RWX ns1
2950074: shifter boot 68-70 B body without console $72.00
2950852: shifter rod E body 1-2 gear 4 speed; rev-1 gear 3 speed $62.00
2950853: shifter rod E body 3-4 4 speed; 2-3 gear 3 speed $54.35
2950854: shifter rod E body reverse gear NS1
2951347: spark plug heat shield B-RB motor $16.93
2951544: choke well cup B-RB engine $28.95
2951545: choke well cup gasket, B-RB engine $3.25
2951673: harmonic balancer A engine 69-71 steel crank $340.00
2951747: bracket A engine pwr steering 1970-79 $17.00
2951834: A engine alternator mounting bracket-non A/C $7.00
2964116: decal Roadrunner deck lid 70-71 standing bird $20.75
2983017: retainer-drive link to crank arm 2sp wiper
all 71+ BJRWXPDC models msq5 $2.60ea
2983067: windshield washer reservoir 70-75 A body 39.60
2983077: connector-windshield washer hose All E & 71+ B Body ss to 5211126 $2.95ea
2983648: positive battery cable 72 B body A engine ss to 3764166 $28.75
2983649: Positive battery cable 70-1 E body 71-72 B body B-RB engine $28.35
2983778: negative battery cable 70-72 b-E body A/B/RB engine, 70-72 A body $14.10
2996454: shifter boot 4-speed 68-70 B body w/console $67.10
2998326: 26" radiator fan shroud 70+ B,E bodies $89.95
2998800: hood nameplate "426 HEMI" $47.85
2998802: hood nameplate "440 MAGNUM" $35.00
2998804: hood nameplate "440 SIX PACK" $33.50
2999001: nut-chrome-remote control mirror door panel ss to 4520061 $5.45
2999806: latch-glove box lock cyl 70-75 VL, 70-74 BJPD ss to: 4216907 $34.20
3402575: Torsion Bar Seals '73-up B, X, S. E T R-body! $12.75 ea
3404182: gas tank filler tube grommet 1970-74 B & E Body $15.45
3404404: battery strap all 70-76A 70-74B 70-74 E bodies $15.60
3404436: battery tray 72+ B body ss to: 2925322 $31.70
3404492: Gas tank 68-70 Charger $305.00
3410038: 4 speed steel shifter fork, 1-2 gear $55.85
3410141: 4 speed steel shifter fork, 3-4 gear ss:4130068 $70.20
3410535: fill tube AT, B, RB engine ss: 3878967 $31.35
3410700: spacer transmission mount all models $7.10ea 2 req
3416002: sill plate 71+ B body $59.25 ea
3418459: thermostat 195 degree, all models up to 1978 exc 6 cylinder $10.95
3418658: shaker hood seal $112.00
3418839: throttle cable same as 3769123 Overall length is 23". 70-74 E Body, 71-80 B Body
3418899: throttle cable stud manual trans $8.35
3418900: throttle cable stud, automatic trans $8.35
3418933: dip stick tube A engine 318/340/360 up to 1976 10.75
3419209: door lock knob, chrome ss to 2956754 $2.50
3420844: gas tank float ***'y 70-74 E body exc hemi $108.00
3420846: gas tank float ***'y 71-74 B body exc hemi & 440 ss to 4051147 $85.50 NS1
3420848: gas tank float ***'y 68-70 B body exc hemi $138.00
3420849: gas tank float ***'y 68-70 P D C model exc station wagon $119.00
3420892: spark plug wires, A engine ss to 4339404 $51.85
3420973: Check valve & grommet pkge, Bendix pwr brake booster ss to 4271382 $16.35
3431074: windshield washer reservoir 1970-71 E Body & 71 B body $36.60
3431154: windshield washer reservoir 70-73 P, D, C $36.20
3431590: windshield washer reservoir 1972-74 B & E body $43.25
3431727: wiper arm, A body rt or lt $27.50
3431975: filter; windshield washer reservoir all models $3.45
3438150: voltage regulator 70 up, all models ss to 5234625 $36.25
3443159: hood nameplate "CUDA 340" $31.70
3443247: "340 FOUR BARREL" hood nameplate $39.35
3443516: "440 MAGNUM" hood nameplate 1971-74 Charger $32.15
3443894: hood-fender rubber bumper, all A bodies $2.50
3444938: "CHALLENGER" fender emblem $34.60
3445223: "R/T" nameplate, stick on Challenger Deck lid $41.60
3454220: clip-door handle to latch rod-70/71 V,L,B,J,R,W,X,P,D,C msq6 $2.50ea
3454221: clip-door handle to latch rod-70/71 V,L,B,J,R,W,X,P,D,C msq6 $2.50a
3454335: door handle gasket, A/B body $2.85 ss to: 3739844 $2.50
3454390: door handle right outside 68-70 A & B-Body $77.70
3454391: door handle left outside 68-70 A & B-Body $77.70
3454485: door striker all models $22.75
3454510: upper door hinge 71+ B body lt side superceeeds to 3788534 $89.85
3461066: rallye wheel ctr, lg bolt pattern Dark style-color $78.95
3461458: rallye wheel center 72-74 A body $62.35
3462094: valve cover breather single outlet ss to round gold colored 53030254 $10.01
3462148: 4 blade engine cooling fan, 6 cyl & hemi ss to 3462185 $55.25
3462415: dipstick tube goes inside the exhaust manifold B-RB HP 70-71 $34.10
3462416: dipstick tube B-RB engine 1968-9 $10.75
3467235: clutch release rod B-RB motors fits B/E Body $36.95
3467764: shifter boot A body 4-speed $68.25
3467766: shifter boot 70-74 E Body, 71-74 B body Square hole $65.95
3488270: switch-back up lights MT ss to 4373814 $13.50
3488609: oil pressure gauge sending unit, all models $94.00
3488623: wiper switch, 2 speed, 71-73 P, D ss to 3746530 $48.00
3488805: turn signal switch assy; 1970-76 A, B, E, C bodies ss to: 4293102 $50.10
3491296: U bolt rear end 6-5/8" long $11.30
3505419: nameplate "DART" quarter panel, trunk or fender $23.50
3505490: nameplate "ROAD" stick on $20.75
3505491: nameplate "RUNNER" stick on $23.95
3508984: inside mirror bracket 70+ B & E Body; $71.20 NS1 but avail on locator
3514186: aux port intake composition gaskets for b-RB 6 pak & aluminum intakes $27.35
3515300: rubber boot-clutch fork bellhousing $14.45
3515383: seal-OUTPUT shaft A-833 4-speed, 727 ss to 4531216AB $13.85
3515920: shield-torque converter case 727 automatic w/ A engine $32.85
3515996: trans filter all 904/727 AT $7.60
3575101: auto trans rubber brake pedal pad 68-70 B-body
ss from 2643707 $7.10 NS1 avail on locator
3575303: steering column coupling 73+ R,W 65-73 full size Chry/ply/dodge $84.10
3575333: AT linkage bushings-rubber 1974 & up. All models $2.50
3575434: AT trans linkage bushings-used from 1961-96 on all models $2.00ea
3580466: road wheel or Mag 500 center dome $51.70
3580894: cap; front wheel bearing cover 72 & up all models msq2 $7.25ea
3583020: battery strap 72+ B body 73-74 E Body $61.35
3587436: side mkr lens, front-amber 72-74 B body, 72-76 A body, 76-80 F body $11.70
3587440: side mkr lens, rear-red 72-74 B body, 72-76 A body, 76-80 F body $10.25
3592360: speedometer cable, A, B, E body 1966-74 ss to 4897646AA $38.45
3593446: grommet-speedo cable thru firewall-all models $2.75
3642334: battery tray A body 68-76 $23.95
3642818: engine mount spool type A engine right side $40.65
3642999: battery tray 69 B body $45.00
3643333: power steering box ss to R3643333 $277.75
3656738: distributor pick up & plate V8, 72 & up electronic ignition $24.45
3656862: distributor reluctor, all V8 electronic ignition $7.50
3671076: grommet, pcv valve/valve cover ss to4694335 msq5 $5.95 ea
3671314: gasket A engine rt angle oil filter adapter to engine ss to 4897939AA 3.75
3671447: block off plate EGR 6 cyl $5.00
3672933: lower grille 72-74 'Cuda & Barracuda $78.75
3679255: fender mounted turn signal chrome cover/lens 72 & up $10.45
3680304: nameplate "DUSTER" 72 & up $32.70
3681601: magnet, auto trans pan, loose chip & metal collector all models/years $4.20
3683947: heat riser package 340 engine $38.10
3695508: mirror, remote lt side 66-70 B body & 68-76 A Body $394.00
3698500: dip stick B-RB HP engine 1970-71 $10.20
3698565: thermostat housing all V8 engine up to 1978 ss to chrome P4286759 $13.75
3698668: trans cooler line bracket all models 72 & up
ss to 4401589 $4.35 NS1 avail locator
3738109: horn relay w/ buzzer 70 up, All models $12.00
3747092: Ignition switch 70-74 E body, 70-76 A body, 70-74 B & C body $61.60
3748263: steering shaft coupler C body w/tilt-tel ss to 3748310 $9.95
3748310: steering shaft coupler ss to 3748263
3749059: Decal-Roadrunner-Standing bird w/helmet deck lid 73-74 Roadrunner $13.70
3751236: Windage tray, B-RB engine $35.75
3751249: cover-goes in place of air tube on exhaust manifold, tear drop shaped
1975& up A/B/RB engines $10.45
3751510: PCV valve cover grommet msq4 $3.95ea
3751613: fuel pump pushrod B-RB engine $23.25
3755972: spark plug wire separator A engine 75 & up $2.10
3760214: door handle rt side 1970-74 E body outside $98.45
3760215: door handle lt side 1970-74 E body outside $98.45
3769123: Throttle cable A engine 360 4bbl, fits 74 up w/ 360 $44.50
3769224: cruise control servo, all models 70 & up
ss to:4549998 $180.00 NS1 avail on locator
3769964: timing cover A engine 69-79 $154.00
3870659: inner throttle return spring, all late model V8s $5.00 NS1
3870660: outer throttle return spring, all late model V8s $5.00 NS1
3780127: water pump all B-R/B engines w/ A/C & 426 Hemi $93.25
3780196: water pump all B-R/B engines w/out A/C $154.00
3781830: radiator cap all modesl 64-91 ss to 52079880AA $9.50
3788534: upper door hinge 71+ B body ss: 3454510 $89.85
3799422: wiper arm assy lt side, XJSET 1979-1981 $42.25
3799447: wiper link assy XJSET models $51.50
3794032: Seal cowel top drain hole HNFG $2.60
3799542: washer reservoir HNFG ss several times to:4467339 $30.95
3870074: crank pully B-RB engine w/ A/C & pwr steering $139.00
3874020: control box-electronic ignition-ss to 4111850 $53.50
3843852: negative battery cable V8 , H N ss to:4450615 $30.20
3847150: drier A/C ss to 4797146 $67.75
3882621: door handle HNFGXSET $61.60
3878967: fill tube AT; B,RB engine ss from 3410535 & 3681316 $31.35
3879325: wiper cam release pkge-parking-2 speed all models $28.50
3879925: pwr steering return hose 50 ft roll all models $121.00
3880999: rear brake T and hose assy 70-74 ABE body $48.95
4002006: gas tank strap j-bolt all models $24.20
4005072: battery tray HNFG SS TO 4490364 $38.95
4014050: upper control arm bumper all models $6.95
4019122: HURST 4-speed shifter $289.00
4022410: decal Roadrunner running bird rt side 68-78 Roadrunner $17.20
4022411: decal Roadrunner running bird lt side 68-78 Roadrunner NS1 avail on locator
4027249: dip stick tube A engine 1979-1981 $9.20
4027092: valve cover gasket B RB engine high perf msq5 $15.70ea
4028123: counter shaft A833 Manual Transmission $42.70
4020181: automatic trans fill/dip stick tube A engine only # avail for A engine AT $27.75
4037651: steering shaft extension converts manual steering box from pwr strg $268.00
4032295: Heavy Duty trans mount 70+ E Body, 71+ B Body, 69+ C Body, F Body $$40.85
4041150: long nut B-RB exhaust manifolds msq4 $5.25ea
4041606: clamp-A engine silicon bypass hose $4.50 ea
4049601: universal hood insulation pad all models, cut to fit $137.00
4049699: Brake pads, cop car disc with slider calipers $61.55 set
4051004: gas tank float ***'y all A bodies $84.20
4057046: repair package speedometer pinion housing all 64-76 models
ss to 4883434AA $7.85
4057093: police car front shocks, fits all F,M,R bodies, G0073504 $30.35a
4057094: police car rear shocks, fits all F,M,R bodies, G0073482 $30.35ea
4095088: valve cover gasket A engine high perf 19.10
4105210: gasket, oil filter right angle adaptor base screw $1.60
4106552: A-833 4 speed transmission gasket kit. $28.35
4130503: A engine 727 trans dust shield-mounts with starter fits 1968 thru 1981 & up ABCEF $11.45
4140724: starter heat shield, all models with round starter. $32.20
4145359: starter, all models same as 4145360 ss to R0171376 $111.00
4145360: starter, all exc direct drive hemi, conventional style ss to R0171375 $110.00
4169629: oil pressure light sending unit $5.70
4173447: Harmonic Balancer A engine engine 360 Ext balanced $180.00
4173223: Extended oil filler tube, cop car piece, all models with stock valve covers $27.25
uses 6030608 cap $2.25and 6030608 seal.
4186180: 6 cylinder intake/exhaust gasket $29.25
4202005: trans pan 727 AT, standard capacity ss to 52118802 $47.35
4202951: Auto Trans oil level indicator all models 904/727, ss from 2466302 $9.45
2287938: EGR gasket A engine msq5 $3.00ea
4213328: Plastic vent remote type
4221653: nipple A engine heater hose to intake manifold $3.75
4241310: pre heater hose carb air all 6 and 8 cyl engines $16.00
4295875AC: 904 pan gasket-reusable plastic $11.95
4318002: sure grip differential additive ss to 4874000 $5.25ea
4339405: big block spark plug wire set-orange color $65.25
4339457: Water valve heater control all models 1979-81 $43.25
4354047: glass run rubber insert 68-69 B Body. Slides into rear channel. $39.35
4373814: switch-backup lights-MT, all models $13.50
4397809: heater hose sleeve, for all models w/ AC usually small blocks $5.10
4383440: brake support-backing plate-right 11x2.5 drums $77.50
4383441 brake support-backing plate-left 11x2.5 drums $77.50
4419337: A/C cycling switch-rotary compressor 1978-81 $50.25
4436772: Brake hardware pkge 10" brakes $23.25
4436773: Brake hardware pkge 11" brakes $23.25
4439058: engine block heater package, use 2 for a V8 ss to 82300749 $33.00
4443436AC: steering pot coupler rebuild package $9.25
4480312: pwr window motor right side all models 66 up $165.00
4480313: pwr window motor left side all models 66 up $169.00
4498064: 67-70 B-Body lower door hinge right & left ss to 55076269 $50.70
4504202: temperature gauge sending unit all models $13.20
5010125AA: ATF # fluid Gallon $13.50
52070427AA: seal axle 8 1/4 $10.25
6008109: insulation to firewall plastic fastener msq10 $3.85
6022891: door hinge pin msq4 $3.95ea
6023092: attaching bolt A engine windage tray 4 req $2.25
6023285: retaining clip for 3418899 & 2418900 throttle cable stud $0.95ea
6023523: battery tray holddown stud wing nut 67-69 all models ss to J3151735 $2.25
6023546: window to regulator rivet msq5 $2.85ea
6024863: bolt w/washer-engine to trans/bellhousing 2 req all engines $4.50ea
6025413: wiper motor mounting nut use 3 $2.85ea
6025752: speedometer pinion housing O ring ss to 6035709 msq10 $2.45ea
6026292: nut outside mirror attachment , 2 req $4.60
6026919: bolt w/washer trans housing dust cover all models $7.00
6027865: bolt w/washer transmission/bellhousing to engine, 4 req all engines $2.70ea
6028750: steering coupling roll pin msq10 $1.75
6029713: bolt timing cover A engine $2.95ea
6029939: plug-floor pan 1/2" hole $2.50ea
6030536: Flywheel Bolt all engines $13.75 ea
6030607: throttle bracket nut for throttle cable retaining bracket $2.95
6030952: caliper adaptor bolts all models 70 & up w/ disc brakes
$4.25ea NS1 avail on locator
6030979: adjusting nut-clutch rod $3.45
6031535: wheel lug-chrome-use for super coupes and kit kar wheels msq5 $4.35ea
6032619: spare tire wing nut $6.20
6030608: seal for extended oil fill tube 4173223
6500650: hose clamp-efi style 5/16"
6500651:hose clamp efi style 3/8"
5010125AA: ATF DEXTRON 3 1 GAL $12.50
52070427AA: axle seal 8-1/4, 9-1/4 rear 2 req $10.45
53009180AA: roller pilot bushing-manual trans $11.60
53021051AB: water outlet gasket intake manifold A engine 1979 & up $2.10
53021195: A engine timing chain tensioner 34.00
55054788-9: Ramcharger taillights rt/lt with black trim 58.60 each
J8130157: seal pkge input shaft Saginaw steering box $17.15
82300234: RTV differ
