mike1965
Here is the dana that will be replacing the 8.75 , we shortened the housing to fit the strange 35 spline axles that came out of the 8.75 and used Caltrac spring perches here are some pix of the housing / spool / 3.54 gears / strange alum. main caps , the axles are going to be drilled for the 5/8's studs and the cover is a strange alum.
