Street / Strip 72 Swinger
draginmopars
Shady Hills, Florida
Same car, different thread
while fixing my pc, decided to clean up my photo bucket files
Well,,, that messed up my other thread,
lost a lot of pics, trying to salvage what i can
so, re doing the time line here.
We ended up buying this car jan 2013, While searching for a roof for a 71 dart
the 72 sat while gathering parts
nov 2014, started this project
We knew it needed quarter work
We had a plan, but, the more we took the car apart, the more that plan changed
While on the rotisserie , might as well, remove all the under coating
then discovered it really needed both front floor sections
it came off really good using a needle scaler
first we tied the frame together, added extra cross members and out riggers under the seat area, to stiffen the floor, before we remove the front floor sections
might as well, move the springs in and widen the tubs, while we are there.
rear shackel height is in correct, due to interference with the rotisserie bracket
this is how i located the rear shackel position
wanting to keep as much trans cross member as possible
we split it in the middle
spread it open then installed 2
1" square tubing, bent into a "U" shape
to tie them back together
in this pic 2 of the"U" pieces are under the raised trans tunnel
the other rearward "U" are for the cross members under the floor and frame connectors
also serve as drive shaft safety loops
the front cross member can be un-bolted to remove the trans
married a "B" body cross member to the 518 trans plate to install the trans
it had the right off set for the mount position
the 4 spacers are to prevent crushing the cross member when tightened
with the front floor sections out
we plated the front frame rails
cut a notch in the driver side
in case we needed to replace the emergency brake cable
applied a little pressure to spot / mig the floor back in
moving to the rear
to get things rolling
narrowed a 81 ford Van Dana
like it for the thick tubes
install a Dr.diff bearing kit, Yukon gears (3.54) with Tru-trac and 1350 yokes
moser welded on the ends and spring pads,
supplied the 35 spline axles, long wheel studs
gonna pull the 540 out of the Satellite
stick it in the dart with a modded 518
That brings us up to date
Am modding a k-frame for the spool mounted engine
got the big block k frame made and installed
eng/ trans is in final positions
move the master cylinder over 2"
to get it away from the exhaust manifold
took me 4 days to mod the firewall into a flat mount area, for the master cylinder,
then weld in fill patches, to close up the original holes
then made 4 spacers for the master cylinder / pedal mount
(there is one hiding on the left side)
still have to make 2 more spacers that go from the pedal mount to the steering column mount
put the front suspension back on
to get it rolling again
thanks- Dartn440
Tqfastfish-kept the spare tire well, can put- jumper cables ect. in there
the tank sets on a section of 1/2" plywood, the size of the tank
the plywood sets level to the trunk floor, with 2- 1" x 1/2" U channel steel
spaced and welded to the floor
same as used on the top,
the top also has a strip of plywood inserted into the U channel
to keep from scratching the tank
there is a PVC wedge, mounted into the trunk lock area, to keep the tank from shifting rearward.
the pump is mounted below the tank, but in front, cause i wanted the tank as far back as possible.
the round hole to the right, is just a patch panel i haven't finished in the pic, it is now been welded in
the red cap on the front right is for the fuel return> haven't ran fuel lines yet
I still have to build a spare tire mount to go in front of the fuel cell, there is room
still sets just a little high in the rear
I think it will squat, by the time I reinstall all the body parts
and 17 gallons of fuel
If not I built some height adjustments into the spring mounts
(AAR) cowl hood for Dominator carb and breather clearance..
Are you going to put a door in the trunk lid or open the trunk to re-fuel? Love the hood!
I'm thinking about
just open the trunk, to fill, to prevent fuel theft,and secure the factory fuel cap, from the inside, so it can't be removed
but, also thinking about a fuel inlet adapter to splice into the fuel tube
to be able to fuel it like factory
Thanks- Abodybomber and jdsduster
This has been an interesting build
bought the car with no eng/trans, but a bunch of parts in the trunk.
went to secure the disc brake hose to the uni-body, found out it is the wrong bracket
was a drum brake car from the factory (/6)
While building the spool mount k-frame
had to allow for the mid plate (1/8")
because the JW bell and converter, didn't want to play well
then when ready to bolt the manual steering box in> couldn't fine the bolts.
car was in the air- looked every where for the bolts
finally let the car down, found the bolts- laying on the cowl.... LOL
never thought it would take most of the day
just to install longer wheel studs
the factory stud head is .765" then found out the moroso is .865"
so that they wouldn't seat square
rather than chuck the rotor into a indexing vice> (would have to borrow)
decided to make a locating pin to center each hole for spot facing them .100" larger
in the mill.
then while turning the rotor decided to shave off the rough casting and true it up
should help with balancing,
In case I want to try "The standing mile run"
I've notice a few cars that like to run the mile
I might give it a try> OD trans with lock up converter.
not much today
after studying the exhaust layout
decided to move the water inlet to the passenger side
got some more bends today>> time for chop and fit..weld
to make it easier for my exhaust guy to hook up to the head pipes.
there is 2 TIGHT "S" bends, plus 2 90's to get the exhaust pointed in the right direction
My labor is a lot cheaper than letting the shop do it (time consuming)
got the head pipes made
will have to wait til Monday to get the 2 elbows, swedged
to see where to fit them, then I can cut off the excess down pipe
but that's ok,
got lots of other things to assemble
finished the head pipes
decided to install "poor boy" torque straps
welded a 5/8" nut onto the back side of each mount
and then a 1/4" x 1" strap welded to the k-frame
next
needed to temp seal the carb to keep anything from jumping into the carb
didn't have a base for a dominator
so cut another top to fit
Once I know the correct height, for the air filter
I'll build a base plate to seal to the Cowl hood and a New air filter
