Leaky fuel tank at sender..
grassy
Nova Scotia
I am ready to start banging my head against the wall.
Last year, when I re installed our gas tank, I bought a new seal, cleaned up that section of the tank and re installed a new sender. It leaked when the tank was filled past the sender.
So I decided to replace the sender since we were going to pull the tank anyway.
Pulled/drained the tank. Took it off. removed the old sender. Cleaned around the sender even though it was quite clean. Installed new sender and another new gasket. Did a quick test. No leaks.
Filled up tank. All was ok. Went out this am..lost 1/4 tank of gas and you can smell it gas quite easily..
Re doing the steps above again would be an excessive in futility...
Any suggestions ?
Thanks
Ian.
Do you have the old lock ring by chance, Ian?
The new ones are junk, and have a difficult time applying enough pressure to seal properly.
I had the same issue, as have many others here.
Well damn, no...I think I tossed it..but I had used the original the first time around..
Is there a plan b or should I start looking for a used one ?
Thanks, Ian.
Well, you could pull it apart and use the rubber gasket to make another thin gasket to compensate.
The gasket you make should not be real thick. Put it back together using the rubber gasket, then the sender, then the gasket you made, then the lock ring.
Essentially what you are doing is taking up some of the space that the lock ring is lacking.
Also make sure the tangs on the tank itself aren't pushed out.
When installing the lock ring, don't use just one tab to seat it, use alternating motions so to keep it centered.
thanks...so the tank has to come off again...darn....
I shall try this..
Ian:)
Not really, I did mine in the car, 74 Dart Sport.
Just get enough fuel out so it's not running out on your face, lol.
Also I recommend using a brass tool to set the lock ring, sparks and gas fumes don't play nice together.
Had the same problem, here's what I did. The small tanks on the tank are usually ben ourwards. Take some time to gently tape them back into place. The next thing I did was to use brake fluid on the gasket. Does two things. lubes then rubber seal to ease installing the ring and after some time the rubber will swell from the brake fluid. Just an FYI. There was a member here that was selling NOS gas snder rings. Bought two for myself. He may have some more.
Halifaxhops thread is closed....and thanks for offering me yours but I cannot take your last one (yet).
When we had the tank out last, we pounded softly on the tabs..
I will try the permtex product...this may do the trick, if not, I may be back :)
The kid can still run the car but keep it under 1/2 ....
I shall report back.
thanks
Ian.
I took the liquid gasket (blue) and put a bead around the hole. I then placed the new gasket on the blue stuff. Added another bead on the gasket and then put the sender on it. I put the locking ring on it and then put the blue stuff all around and in the area of the outside of the sender.
Have used that twice and it worked great.
I was wondering if a little pliers action on the lock ring would do it.
There's no need to pull the tank -- I just had my sender out and back in with a new gasket in 20 minutes.
