for sale.1970 plymouth fury 111 convertible
Johnnysmoke
Member
32 mechanic st
Rating - 0%
0   0   0
Hi all. I am selling this 1970 plymouth fury 111 convertible with a 383 two bbl automatic.Needs work and restoring.Has n't run in 5 years and was running rough when I parked it.I put in a new alternator new spark plugs,new plug wires,new distributor cap rotor and points.This car is running vary strong now. Transmission is good.Haven't checked weals yet.Having trouble getting them off with problems i have physically.Some reason the drivers side rear weal is locking. Probably brakes.Top works.Trunk will need sealing.And will need a body man.This is located at my home.And must be picked up there if you bye it.I can not ship it.I'm asking 2500
All it takes is a quick look at most people's profile to come up with a zip code...
12090 Zip Code (Hoosick Falls, New York)
No build sheet.What is a fender tag?
