[SOLD] 68 Plymouth Valiant Signet more door
Sedanman
67-9 Valiant specialist
chicago Il
I have a 68 Valiant Signet 4dr that is in pretty nice shape. It was a /6 auto car and someone installed a Dip[lomat front suspension in it and had to modify a few things to make it fit and they didn't do a very good job of it. I have everything to put it back to a /6. The body is pretty nice and has nice paint and was Ziebarted in the past. The underside is all very clean with no holes or rust/rot. The inerior is like new. I did do a magnet test to the body and there is bondo in the front fenders down low and in the lower RH 1/4 but the body work was done well. It has Crager's all the way around with great tread on the RWL tires. The rears are SBP and the fronts are uni lug. They used the disc's from the diplomat but didn't change the master or control arms. It comes with the correct /6 suspension from a 71 dart,running /6 drivetrain including exhaust,spare rolling rear suspension,4 14" SBP steel wheels and tires and whatever else I can dig up to put it back to a stock driver. $2900 obo and bring a truck (for all of the parts) and trailer (for the car)
What it needs: take out the diplomat suspension and install an a body suspension and put it back to stock using the supplied parts or do what you want to it. It could be running and driving in a few weeks with everything I have including a factory 68 manual. It does need a new engine harness since they butchered the original and I wouldn't trust it but I do have one coming. I work 6 days a week and 10-13 hour days so it will be months before I can get it up and running again
It will have a black hood on it,not the white one.
