Moparparts
Please see additional pics on the next post of this thread.
FOR SALE: Very Complete Original 73 and up Power Front Disc Brake Changeover set up. This set up includes: Large ball joint upper control arms, Spindles, Dust shields, Calipers with brackets and bolts, Rotors, Power brake booster, Pedal linkages, Firewall and inner fender support braces, Master cylinder, and Disc brake proportioning valve. The ball joints have been removed and are not included, as they need replaced anyway. This set up came from a non-op car that sat for about 15 years. The system had some brake fluid in it, but I am sure the components will need rebuilt, as well as the ball joints and bushings replaced. The rotors still have some thickness and may be able to be cut, but do have some pitting from sitting. The dust shields do have some rust and small bends, but should be able to be cleaned up OK for a driver. The booster pedal linkage did push OK and is not stuck. At this time, I am selling this complete set up together. Price would be $500 for all the pieces pictured and described plus shipping from Pa 17086. Post or PM.
