[FOR SALE] Big block setup from a body
dodge71demon
Indiana
If anybody wants a nice big block setup and if I do not sell my 69 Valiant I MAY be parting ways with the setup this winter and go small block I have some plans for my Scamp and it involves some items off the Valiant but only time will tell as I type this I'm going through my inventory
Mild build 400 low deck complete intake to pan (a body pan pickup available)
Heads reworked with 2.14 intake valves can't tell you the head number off the top of my head
Choice of single or dual plane intake (now has single see converter note below)
Schumaker tri y headers
stock 727 (new converter but not enough stall for this motor and intake)
Becool radiator
Lokar throttle - kick down cables - bracket for Elderbrock carb
can hear running and drive at this time
$3500.00 for everything no carb- air cleaner - alternator
I can also part with a rebuilt truck Dana 60 3:54 gears modified to A body specs with drive shaft for 108" a body using above with disc brakes and u bolts for an additional $2000.00
I will not sell this separate unless motor a tranny sells first
Located Syracuse Indiana 46567 bought where is as is no warranty no mounts K Member etc PICK UP ONLY
Picture shows Champion radiator but have since changed to the Becool
I may move SOME off the price
