Oil Filter Plate
Yes I have one with the 90 swivel part too and remote lines to a remote filter.
It is suppose to have less restriction and it is a nice part!
You need to make sure you get the part that screws into the block and holds the plate to the block, then allows either the filter to screw to the other treads on the adapter or allows the swivel part to connect.
I just had plans to get the adapter to put the filter onto it. Does it work well, no leaks or issues?
How many people have ditched the 90? I used the 90 with the TTI's and filters where easy enough to change I put a bag over it and took it off.
But it did leak on me once a new gasket set made it happy.
Just curious if a flate plate would be easier better flow etc.
has a better than stock seal. It is a lrger flat type o-ring and a machined billet plate.
no issues for me..
