[SOLD] A-body 8 ¾ drum to drum rear, 4.10 sure grip, LBP axles
physixx
Edison, NJ
I have a complete A-body, drum to drum 8 ¾ rear end assembly that came out of a 73 Duster. The rear was installed in the Duster but the project never got finished so this rear never saw any miles. It is an original A-body housing with the -489 center section fitted with 4.10 gears, sure-grip differential and the smaller 7260 pinion yoke. It also has aftermarket LBP axles with screw in studs and 10 x 1 ¾ brakes that are in great shape. It also looks like new brake hardware was installed. The drums, however, were drilled to fit the LBP axles. I would like to get $1500 for the rear plus the shipping. I also have the shock plates, U-bolts and nuts for an additional $40. In addition, if the 4.10 gears are too steep, I have a complete 3.23 sure grip -741 center section that I can put in to replace the 4.10 center section. The price would then be $1400 complete, drum to drum.
Ken
Edison, NJ
Any interest in selling the 3.23 Center Section you mentioned? I could arrange pick up if the price is right. We have family in Edison NJ.
Hey can you see how much to ship to central ca and whats the lowest ypud go for everything?
