65LoveAffair
Whovian
I was fighting with removing a heater hose from my DD recently. I couldn't get the factory hose clamp off where the hose attaches to the water pump.
I really hate the OEM spring type Mubea hose clamps that krazykuda detailed in a post a little over a year ago.
The problem I have always had with them is that I can never get a wrench down there to squeeze the ends together to get them off.
And if I do get the wrench on it, once I squeeze it together, the clamp usually turns around and slips off at the point where it is completely impossible to get the wrench back on.
Plus, I'm too cheap to go to one of the box stores and pay at least $30 for the proper cable-style pliers to remove them the right way.
That's when MommaCat came up with a brilliant idea. I'm sure others have thought of this, and use this technique, but I have never seen it mentioned or written up elsewhere (I did search), so I thought I would share and see if anybody else does it this way.
First, I took an old, used screw-type hose clamp. I'm sure a new one would work, but it might get bent out of shape.
I then slipped the clamp around the prongs on the OEM spring-type clamp.
Now, all I had to do was tighten the spring-type clamp with either a screw driver or a socket wrench, and it would release the tension on the clamp.
As a bonus, it would hold that tension, keeping the spring clamp loose while I worked to release the heater hose from the water pump.
It was really a brilliant solution, and it just reaffirmed the fact that I married a unicorn! Hope this helps somebody else out in the future!
