Hey Eric, you should have said hi! I made 12 passes, improved on my time from the last weds nite drag, I went 13.71 @ 103 mph. My tires spin a lot, running radial tires, learning to drive this car with a 4-speed is a real challenge. The temps were warm and high humidity hurt the times too, hopefully I get some dot slicks for next time and go quicker. I think I may have some ignition issues, running it up to 6400 rpm, popped and sputtered a few runs. I didn't break anything so it was a pretty good nite! My friend Mike was running the blue 66 Coronet, he is also a member here, I think there was only 3 mopars running that nite. Cool pics, thanks!
